Thread: Formula in family's parameters.
    May 11, 2016
    5
    07:36 PM
    Hi!
    I have spent all the morning trying to create a conditional formula to center an object, but Inconsistent units don't stop to appear....
    See the image below:
    The orinial formula was: IF(Centre,Desplašament_X_Conducte_Imp=(Ample/2)-(Ample conducte impulsiˇ/2),Desplašament_X_Conducte_Imp)
    I think that this problem is because i must eliminate the units, but i don't know how.
    I hope u can help me with that problem.
    Thanks!!
    1,483
    08:36 PM
    Think you should read this, it helped me a while back:
    http://www.revitforum.org/tutorials-...lize-them.html
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    220
    12:36 PM
    First off, this formula won't work as you are creating a circular reference by referring back to the same parameter you are putting the formula in (You need to have a second parameter). Second, it looks like you need to introduce the mm units back into the formula (or not cancel them?) but I can't exactly tell what the parameter types are.
    So you need something along the lines of this:
  1. Revit Family Formula Help
    By knkagaki in forum MEP - Family Creation
    Last Post: June 23rd, 2015, 04:25 PM
  2. titleblock family formula/Parameter
    By lhudson in forum Architecture - Family Creation
    Last Post: June 2nd, 2015, 07:40 PM
  3. Family Type - Formula or Lookup?
    By stevienet in forum Architecture - Family Creation
    Last Post: September 15th, 2014, 04:32 PM
    Last Post: August 15th, 2013, 01:15 AM
  5. Formula for controlling 3 yes / no parameters for visibility
    By RevituP in forum Structure - General Questions
    Last Post: November 19th, 2012, 11:05 AM
