Thread: Steel Tonnage Takeoff - Isolated Section
    November 28, 2011
    Ontario, Canada
    154
    03:34 AM
    Hello All
    I have already done a steel take off for my project.
    So what I need to do now is do a steel take off of just brick support framing we have added. I have placed the brick support framing on a separate workset hoping that this will work and also for visibility on plan.
    My first thought is that is to take the difference of of the total i did before and the total of the structure now but I can't use that method because we have made some modifications to the other parts of the structure.
    So that is my question, is there a way I can do a steel take off of certain parts (in my case, the fore mentioned brick support framing).
    Suggestions/comments?
    Member truevis's Avatar
    January 7, 2011
    112
    03:34 AM
    Can you simply make a schedule filtered by whatever you want, and calculate the totals?
    November 28, 2011
    Ontario, Canada
    154
    03:34 AM
    this is one solution that I came up with earlier today. I created a new phase and changed all the steel that I need to do the take off for to the new phase I created. I then created a duplicate take off of one I used for the whole building and added a parameter for the phase and voila, its working fine except the take off didn't include the all the steel plates I modelled in place.
    890
    05:34 PM
    You want to do a MATERIAL VOLUME list.
    Then you can sort by material and have it seperate the changes with a blank line, also use the item in the list that says "material:volume" not the one that just says volume.
ID:	27261   Click image for larger version.
ID:	27262   Click image for larger version.
    March 21, 2011
    Brisbane
    291
    05:34 PM
    We have added a parameter to our framing and columns called “Zone” to be able to differentiate between different section of a building.
    It is not 100% as it still relies on human input though and with that comes human errors.
    March 21, 2011
    Brisbane
    291
    05:34 PM
    We have added a parameter to our framing and columns called Zone to be able to differentiate between different section of a building.
  1. Revit Steel Tonnage
    By akaplan in forum Structure - General Questions
    Last Post: June 14th, 2016, 02:50 PM
  2. Wall joins in isolated views
    By debbieg in forum Architecture and General Revit Questions
    Last Post: February 19th, 2014, 02:58 PM
  3. Steel material tonnage in schedule
    By Clara2011 in forum Structure - General Questions
    Last Post: March 7th, 2013, 05:40 PM
  4. Steel tonnage cautions
    By Alfredo Medina in forum Structure - General Questions
    Last Post: September 28th, 2011, 06:23 AM
