Thread: REVIT 2017 - DEPTH CUE - Can't click "show depth" / greyed out in view template
    Junior Member jmabbey's Avatar
    April 18, 2013
    6
    04:07 PM
    I love the new option of depth cue in the Graphic Display Options. I am able to apply it to any new section or elevation. However, It will not let me apply it to an existing view template, and I'm unsure why. The option is greyed out, see attached image. Has anyone come across this issue yet?
Name:	revit forum.png
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    01:07 PM
    With View Templates, the selections are setting specific. So while there are multiple options to change in the same window, you can only change that specific setting in the View Template. Close out of that window and switch to Depth Cueing.
    April 12, 2017
    05:07 PM
    The discipline of your view has to be either Coordination or Architectural. (For whatever stupid reason. God forbid other disciplines want control over how their views look).
    Junior Member theoryshaw's Avatar
    March 2, 2012
    Madison
    32
    03:07 PM
    Also, i believe it has to be in a 'section' or 'elevation' view... not a detail view, for example.
  1. Wall foundation depth - "Varies"
    Last Post: October 14th, 2015, 10:43 AM
  2. Help: Custom countertop family breaks at depth less than 13"
    By loveisalluuneed in forum Architecture and General Revit Questions
    Last Post: May 24th, 2014, 03:16 AM
  3. how do i change a component on workset "View XXXX" to another one (its greyed out)
    By shanetuai in forum Architecture and General Revit Questions
    Last Post: February 5th, 2014, 02:52 PM
  4. Adding "depth" to Toposurface?
    Last Post: March 19th, 2013, 04:19 PM
