Thread: Revit Structure Wall Material
    July 25, 2016
    9
    03:18 PM
    In Revit on a project I have lower ground floor and ground floor and I am trying to distinguish between walls and column that merge, therefore I am putting them on different shades
    I set the walls light grey
    I set the columns dark grey
    However
    On Lower Ground floor all the walls are all dark grey with the walls displayed as I want on ground floor.
    This is exactly the same wall and same material
    Visual style and detail level are the same
    Any ideas?
    Junior Member mfleming's Avatar
    January 31, 2014
    15
    10:18 AM
    Quote Originally Posted by kobrien View Post
    However
    Any ideas?
    How are u controlling them? Filters, Manual Overide, Material, model cat override etc?
    If filters provide info on the filter and order of them. Maybe a screenshot.
    Matt
    926
    01:18 AM
    unless you have done some kind of visual over ride, your columns AND your walls will have their color controlled by MATERIAL
    (which you stated was the same material)
    And that is where your problem is.
    You will need to add a filter, or a Visibility Options override
    July 25, 2016
    9
    03:18 PM
    Thank you.
    I had a visual over-ride in place and i managed to correct the problem
    Thanks
  1. Revit crashes when changing wall structure
    By Jozi in forum Architecture and General Revit Questions
    Last Post: April 6th, 2018, 07:00 PM
  2. Wall material display - Fill vs Material pattern
    By ncowherd in forum Architecture and General Revit Questions
    Last Post: August 11th, 2015, 03:39 PM
  3. Wall cleanup...with wall material extension
    Last Post: May 7th, 2015, 11:25 AM
  4. Question on Revit Material (Custome Wall/Floor Tiles)
    By kickstartt in forum Architecture and General Revit Questions
    Last Post: October 7th, 2013, 11:13 PM
    Last Post: June 14th, 2013, 11:45 AM
