Thread: Rendering with sun and internal light?
    July 14, 2016
    86
    11:50 AM
    Do you guys have a good patent for that?
    I've been pulling my hair out trying to find the right balance, either the sun light was too strong (while I really like those long shadows going inside the room), or the internal artificial light were way to dim (including studio lights).
    Adjusting exposure didn't help much.
    So I ended up doing 2 renderings, one with internal lights only, one with external light only, and then export them both, put them to photoshop, overlay and make one of them 40% transparent, so that the image is still bright but sunlight shows up nicely too without overburning the surfaces.
    Do you have better patent for that?
    1,689
    01:50 PM
    have the same issue, and am trying you solution as we speak, but it would be nice to not have to do stuff in photoshop
    July 14, 2016
    86
    11:50 AM
    It really takes 1 minute in photoshop, but it's a pain that you need to render the same image twice.
    I actually used free Gimp or that purpose, but Photoshop will do exactly same work.
    1,689
    01:50 PM
    Yep easy fix, and does make a lot of difference. But like you said pain in the neck to need to render twice.
Name:	3D View 7-4.jpg
ID:	27839   Click image for larger version.
Name:	3D View 7.jpg
    2,852
    04:50 AM
    Rendering is like photography. You wouldn't see the lights in a photograph so you won't see them in a render. You see them in IRL be side your eyes have a hell of a lot more range than an image. The process you're using is basically making a High Dynamic Range image.
    Member uaifestival's Avatar
    May 28, 2014
    Tokyo
    101
    08:50 PM
    Last time I had this problem I set the internal light , studio light, to a more powerful lumen effectiveness. It helped. Once I had to
    do the internal renndering thoe lights were turned invisibile, and I used a different set of lights.
  1. Sun Light in Interior Rendering
    By theshell07 in forum Rendering and Gallery
    Last Post: January 19th, 2016, 09:22 AM
  2. Internal Lights not rendering.
    By PS_Draughting in forum Architecture and General Revit Questions
    Last Post: December 2nd, 2014, 02:13 PM
  3. How to get light into a room when rendering?
    By commando17 in forum Architecture and General Revit Questions
    Last Post: April 15th, 2014, 01:10 AM
  4. Need help with light rendering
    By jmussett in forum Rendering and Gallery
    Last Post: January 7th, 2012, 12:58 PM
  5. exterior light for rendering
    By Pickens in forum Architecture and General Revit Questions
    Last Post: July 11th, 2011, 04:37 AM
