Thread: Funny Guardrail
    November 23, 2012
    97
    09:07 AM
    Funny Guardrail
    I'm building a simple guardrail.
    It needs a bottom rail running at the floor level.
    When I set the bottom member to the 0" elevation, it interrupts the posts, and I need the posts to run to the 0" elevation. Is that normal, what's that?
    If the bottom member is placed a fraction above the 0" elevation, the posts are not interrupted. That's a crude fix, is there a better way?
    (file attached v2017)
    6,314
    12:07 PM
    You can add a negative offset into your balusters to get them down to the correct elevation.
    November 23, 2012
    97
    09:07 AM
    Thanks for the suggestion:
    So I did that, set the baluster to -4" offset, and the base ends up 4" below the bottom rail, which is 4" below the base of the rail system. Am I missing something?
    6,314
    12:07 PM
    Sorry - I didn't realize it did that when I tested it
    I'm out of ideas other than using 2 railings.
    November 23, 2012
    97
    09:07 AM
    Thanks for looking. So I'll just hack it somehow, and move on.
    Seems like a very odd behavior, I wonder what for/why that?
  1. Open joint in glass guardrail made with curtainwall system
    By mthurnauer in forum Architecture and General Revit Questions
    Last Post: August 8th, 2016, 07:30 AM
  2. Funny IM Moment #1
    By tzframpton in forum Out There
    Last Post: October 29th, 2013, 07:00 PM
  3. funny sign
    Last Post: November 1st, 2012, 02:27 AM
  4. Funny math?
    By DaveP in forum Out There
    Last Post: November 8th, 2011, 01:06 PM
  5. Guardrail on sloping parapet
    Last Post: August 26th, 2011, 03:58 PM
