Thread: Exporting from Navisworks timeliner
    Member Iberkim's Avatar
    June 24, 2016
    Denmark
    83
    07:27 AM
    Hi guys
    Is it possible to export an actual model from a certain time in the timeliner? I can't seem to do it vanilla. But are there some kind of addin that would make it possible?
    And before you ask, I need it for a test I am doing for AR during the construction phase.
    /Kim
    4,442
    06:27 AM
    There's a post on the internet somewhere that describes how you can connect timeliner to Max, so I presume the answer is "yes". But how, well...
    11,098
    12:27 AM
    I believe that was done through tying the timing sequence data (pulled from timeliner) OUT, based on element ID. I remember because- in the class taught at AU about it- they had to use a script in Max (MaxScript?) to rename all the items absed on element ID, to pull that timing data back in.
    4,442
    06:27 AM
    Yeah that sounds familiar, and way too much work for me to get excited about!
  1. Timeliner + Elements
    By Drew in forum Coordination Tools
    Last Post: June 1st, 2016, 03:09 AM
  2. Best Practices for exporting to navisworks from revit
    By nick_h in forum Coordination Tools
    Last Post: March 19th, 2014, 11:31 PM
  3. Exclude Grids when exporting to Navisworks?
    By tzframpton in forum Coordination Tools
    Last Post: January 18th, 2014, 07:03 PM
  4. Pipe Fittings Missed Out When Exporting to Navisworks
    By Ye Zaw Lin in forum MEP - General
    Last Post: October 31st, 2012, 01:58 PM
  5. Exporting to Navisworks" Error message"
    By djdoel in forum Structure - General Questions
    Last Post: May 10th, 2012, 02:28 PM
