Thread: Project Base point as a parameter
    July 22, 2015
    4
    08:32 AM
    Morning All,
    Hopefully someone can help. I am trying to put the Project address and project base point onto a model title sheet.
    The address is easy enough to set as a parameter but i am at a loss on how to get the project base point (Northings Eastings, Elevation and angle to true north) set up.
    Any help would be fantastic!!!!
    Cheers
    Ben
    April 22, 2011
    503
    07:32 AM
    Coordinates can not be scheduled 'out of the box'. You have to work out a workaround. We use a excitech addon.
    I tried the APL tool but this will lead to asci lists that can't be linked / easy converted and imported (without workarounds, but i bet Dynamo would be the way from there. Not my thing)
    July 22, 2015
    4
    08:32 AM
    Thanks, been trecking through the internet trying to get some answers.
    April 22, 2011
    503
    07:32 AM
    Ok. Let us know if you find something more worth sharing then..
    June 2, 2015
    17
    07:32 AM
    saw this as an answer. not ideal
    https://forums.autodesk.com/t5/revit...k/td-p/5950289
    interested to know about the excitech plugin though.
    Kingdom of Denmark
    4,278
    09:32 AM
    Sure is possible with Dynamo. This one even creates the Global Parameter - But still room for human error (have to remember to run the script)
  1. Adjust project base point vs survey point in elevation
    By iru69 in forum Architecture and General Revit Questions
    Last Post: March 13th, 2018, 04:56 PM
  2. Project Base Point | Survey Point | Absolute Elevation Issue
    By siqbal16 in forum Structure - General Questions
    Last Post: March 29th, 2016, 10:16 PM
    Last Post: October 23rd, 2015, 04:15 PM
  4. Relocate Project VS Moving Project Base Point
    By Exar Kun in forum Architecture and General Revit Questions
    Last Post: August 11th, 2015, 07:07 PM
  5. Project Base Point
    By dcouper in forum Architecture and General Revit Questions
    Last Post: March 15th, 2013, 02:45 AM
