Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: HEEEELP!!!!! Underlay+Ceiling
    Member RabbitHole's Avatar
    January 4, 2011
    98
    02:28 AM
    I really need some help here guys.
    This is a building being modeled by a user in my office.
    I have posted about this previously and now it is getting urgent.
    http://www.revitforum.org/showthread...ng-in-underlay
    If you look at t/o level two and try to set the underlay to the same levels ceiling plan it does not work.
    The same is done to levels 3 and 4 ................ and here it works.
    Could someone help with a fix or a reason as to why this won't work?
    I have set the ceilings that should showing to a cloer to clarify.
    RED+ 2nd floor
    Blue= #rd floor
    Thank you in advance
Name:	T-O 2D Floor RCP.jpg
ID:	334   Click image for larger version.
Name:	T-O 2D Floor.jpg
ID:	333   Click image for larger version.
Name:	Properties Tab t-o 2D floor.jpg
ID:	336   Click image for larger version.
Name:	T-O 3RD floor  with ceiling underlay.jpg
    December 17, 2010
    Pembroke Pines, FL
    571
    06:28 AM
    Try using the 02-T/O 2ND FLOOR as the underlay instead of the T/O 2ND FLOOR
    It seems that you have a different plan as your source for the ceiling plan
    hth
    10:28 AM
    COuld you post (part of) the file? Would like to take a stab at it, but this is kinda hard without the use of Revit itself. I believe we covered all the usual suspects by now.
    January 4, 2011
    98
    02:28 AM
    Hi Martjin.
    i tried to load the file but it is a bit to big right now.
    Will have to try and reduce tonight or find another way to get to you.
    We can try dropbox.
    January 4, 2011
    98
    02:28 AM
    Quote Originally Posted by JCM View Post
    hth
    Hi Juan
    Dont realy get what you mean. Sorry.
    The reason why you can see the t/o 2nd floor (bathroom fixtures) showing in the t/o 2nd floor RCP is cause I had it switched on as the underlay earlier to check other ways around the issue.
    please elaborate on your thoughts casue I need it.
    Thanks
    Cheers
    Kingdom of Denmark
    4,267
    11:28 AM
    How big is the file now ? We could temporarily allow a large file to be uploaded if needed - I understand that its getting urgent
    January 4, 2011
    98
    02:28 AM
    Its at 52 MB right now.
    I could chop a few levels of and see what I get.
    December 17, 2010
    Pembroke Pines, FL
    571
    06:28 AM
    Quote Originally Posted by RabbitHole View Post
    Hi Juan
    Thanks
    Cheers
    Well, I saw from the screen capture that the plan you had as the Underlay was labeled T/O 2ND FLOOR and the view you were in, was labeled 02-T/O 2ND FLOOR so I thought that maybe there was another plan view with a very similar name as the one you need. and perhaps the settings for the view range or visibility settings you were changing might not be for the right view.
    January 4, 2011
    98
    02:28 AM
    Oh ok. Make sence. I had the underlay set to the same level but I am referencing the Ceiling Plan.
    Check this blog post
    http://revitclinic.typepad.com/my_we...ientation.html
    And this video
    http://www.screencast.com/users/JSmi...b-c50bcda57bf4
    Alex Cunningham's Avatar
    Northern California
    3,576
    02:28 AM
    OMG 52MB is killer for a DB to handle
  1. Underlay not showing
    Last Post: December 8th, 2015, 06:53 PM
  2. Ceiling
    By shiner79 in forum Architecture and General Revit Questions
    Last Post: May 25th, 2011, 07:51 PM
  3. Recessed Ceiling
    By dlggnation in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2011, 07:24 AM
  4. Ceiling help
    Last Post: May 3rd, 2011, 11:27 AM
  5. Reflected Ceiling not showing in underlay
    By RabbitHole in forum Architecture and General Revit Questions
    Last Post: January 7th, 2011, 02:18 PM
