Results 1 to 10 of 12
Thread: Schedule of views that use a selected Scope Box
    June 18, 2015
    75
    11:57 AM
    Does anyone know of a way to find out which views have a selected scope box applied to them? I'm looking to know which drawings are going to be affected if I modify a scope box.
    April 24, 2014
    Brisbane, Australia
    24
    01:57 AM
    Scope boxes are automatically visible in all 3D and views where the scope box intersects the cut plane.
    If you select a scope box, in the properties palate there is a 'views visible' button.
    If you click on that button it will open a dialogue box and display a list of views and tell you whether or not there is automatic visibility or if an override has been put on a view to hide or display a scope box.
    Hope that helps.
    June 18, 2015
    75
    11:57 AM
    That is useful for helping me figure out where those are showing up (and folks are potentially modifying them hehe). I was actually looking to find where those scope boxes were applied to views to control the extents of the view. I was trying to figure out where the effects of modifying a particular scope box would cause the view extents to change
    April 24, 2014
    Brisbane, Australia
    24
    01:57 AM
    Sorry read your question to quickly, not sure about this one. I noticed the other thread you commented on and would also be interested if they were able to find a Macro to do this. Good luck!
    September 19, 2015
    162
    04:57 PM
    This free app provides an "overview of where you have used which Scope Box":
    Scope Box Purge
    June 18, 2015
    75
    11:57 AM
    Thanks! that looks promising
    January 27, 2017
    48
    03:57 PM
    Sorry for reviving this old thread but is there an update to this?
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    415
    05:57 PM
    January 27, 2017
    48
    03:57 PM
    Quote Originally Posted by Bjorn_K View Post
    Thank you Bjorn! From what I can gather from the snapshot is that this script allows for the "scope box" value to be added to a shared parameter added to your views, which therefore allows you to schedule the views taht have scope boxes assigned to them. I will give it a try. Thanks for sharing!
    January 27, 2017
    48
    03:57 PM
    I tried it and it seems I can't match your code block. What am I doing wrong? I copied your code 1 to 1. Dynamo Version 1.34
  1. 3D Views and Scope Boxes
    By DaveP in forum Architecture and General Revit Questions
    Last Post: June 14th, 2018, 05:10 PM
  2. Way to track which views have which scope box assigned?
    By aperte in forum Architecture and General Revit Questions
    Last Post: October 17th, 2016, 08:43 PM
  3. Grids, views and scope boxes
    By Charles Karl in forum Architecture and General Revit Questions
    Last Post: March 30th, 2015, 06:32 PM
  4. Print Selected Views/Sheets lockups
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: November 4th, 2014, 04:04 AM
    Last Post: May 31st, 2012, 05:45 AM
