Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: RFO Benchmark v3
    Rotterdam, South Holland
    3,071
    10:23 AM
    RFO Benchmark v3
    Well, after all sorts of trials and tribulations, RFO Benchmark v3 is finally here. My apologies for the delay.
    Please post your results in
    RFO Benchmark v3 2017 results
    RFO Benchmark v3 2016 results
    RFO Benchmark v3 2015 results
    This v3 benchmark changes a few things you should be aware of.
    1: Model creation now includes benchmarking of area plan creation and View Template use. Note that Revit Structure does not have Area Plans, so these two tests will not run for RST 2015 & RST 2016. With Autodesk abandoning the separate verticals approach this will not be an issue moving forward.
    2: Exports have been moved to a separate Export group, and expanded to include export to DWF as well as Vector & Raster printing. The latter two require the Microsoft XPS Document Writer printer be installed.
    3: Graphics without Hardware Acceleration has been removed from the Standard set. This test was added to help make the argument that decent GPUs and Hardware Acceleration where worth the extra cost. I think that argument has been made, so this rather slow test series has been relegated to the Expanded test only, to make room for the Model and Export additions.
    4: The results now show update status. This is important as the R2/.1 releases show some real performance improvements over the corresponding FCS release.
    5: To ensure consistency and address some of the failures some folks have been seeing, the benchmark now backs up and completely replaces your user Revit.ini. Upon successful completion your Revit.ini is restored. If you do have a failure, use the _Terminate Benchmark link to kill the benchmark & Revit and restore your Revit.ini.
    It goes almost without saying that v3 benchmarks cannot be compared meaningfully with previous versions. Thus version 3 is provided for Revit 2015-2017 to facilitate year to year comparisons.
    Also, be aware that Revit 2017 FCS has a pretty serious memory leak in the DWG export code. As a result, the Expanded test is likely to crash or take a day or more to process. The expanded test is really only appropriate for extended testing for major purchase decisions, but for 2017 it is even less appropriate unless you have 2017.1. The Standard set will demonstrate this improvement in 2017.1 more than adequately.
    EDIT: Error work arounds.
    1: Failure at New File: There is a bug in 7Zip that results in empty folders being extracted as zero length files, so the Output folder is not available for Revit to save files to. You can address this two ways. Either don't use 7Zip and use the built in Windows Zip tools instead, or manually delete the zero length Output file and create a folder in its place.
    2: If you are testing in VDI, and the test is failing at the Exports, check to ensure your VDI environment is set up to provide print dialogs on the VM, not on the client.
    3: If you need to test in "demo" mode, you have to build a "demo" deployment using 111-00000000 as the serial number and install from the deployment. The "demo" mode when installing directly from the downloaded installer requires logging in to Autodesk's services to run, which cannot be automated.
    Thanks!
    Gordon
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    01:23 AM
    Gordon, What do I have to modify if 2017 is installed on a drive other than C:\ ?
    Guessing that is why Windows is saying it can't find Revit 2017, even though it is installed.,
    3,071
    10:23 AM
    Yes, in the Resources folder is an XML file, and at the end of the XML file is a node where you can revise the path.
    Gordon
    April 29, 2011
    Decatur, Georgia, United States
    8
    04:23 AM
    I am getting an error where the "Journal file could not be run to completion"...any one else seeing this?
    3,071
    10:23 AM
    Quote Originally Posted by scottcwaelde View Post
    Scott, which year, vertical and test set?
    Gordon
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    245
    10:23 AM
    I got my new computer yesterday and wanted to try the test.
    I have the problem it opens Revit 1 time and then stops doing anything. The poweshell script keeps running but nothing happens.
    I am using Windows 10 PRO and have Revit fully updated.
    3,071
    10:23 AM
    Quote Originally Posted by mjajansen View Post
    mjajansen,
    is your Revit a licensed copy, or a demo? If the latter, you can add -okDemo to the end of the shortcut target property. Just make sure you open Revit once and OK through the first launch questions. If it's licensed PM me and we can set up a GoToMeeting to look at it in more detail.
    Gordon
    December 25, 2011
    The Netherlands
    245
    10:23 AM
    I tried it again and it worked now. It just takes 3 minutes for the second time to open Revit.
    April 29, 2011
    8
    04:23 AM
    Gordon, i keep getting this error, any thoughts? I am on subsription, i have BDSP 2014-17 installed. i get this error when benching. I have tried this on my machine and a dell xps.
    OS Name Microsoft Windows 10 Pro
    Version 10.0.14393 Build 14393
    Processor Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s)
    GeForce GTX 980 4GB 256-Bit GDDR5
Name:	rfo bench v3.JPG
    April 29, 2011
    8
    04:23 AM
    Gordon
  1. RFO Benchmark v2
    Last Post: March 13th, 2017, 09:44 PM
  2. RFO Benchmark decision thresholds
    Last Post: August 2nd, 2015, 07:36 PM
  3. RFO Benchmark Sys Info validation
    By Gordon Price in forum Out There
    Last Post: February 28th, 2015, 09:34 PM
  4. CPU benchmark 3Ddmax Mental Ray
    By gaby424 in forum Hardware and Infrastructure
    Last Post: May 14th, 2011, 07:37 PM
