Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 67
Thread: RFO Benchmark v3 2017 results
  1. #21
    February 5, 2017
    10:35 PM
    Results of a Virtual machine @draftingcloud.com, mid grade package.
    RVT 2017 - Standard set - 2017.02.03 @ 17.06.45 on W10-02
    RFO Benchmark v3.0 (build 17.10.2016)
    RevitForum.org
    Run on Autodesk Revit 2017 FCS
    __________________________________________________ _______________
    Update
    18.57 update previous version file
    Model creation benchmark
    4.66 opening and loading the custom template
    17.47 creating the floors levels and grids
    32.92 creating a group of walls and doors
    60.83 modifying the group by adding a curtain wall
    18.58 creating the exterior curtain wall
    13.59 creating the sections
    6.35 changing the curtain wall panel type
    15.29 creating area plans
    2.68 creating and applying view template
    172.37 TOTAL
    Export benchmark
    87.67 export all views as PNGs at 300 dpi
    138.64 export all views as DWFs
    220.60 export all views as DWGs
    113.63 print all views as vector *
    135.59 print all views as raster *
    Notes:
    * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
    144.18 render
    Graphics benchmark
    7.02 refresh Hidden Line view x12
    7.09 refresh Consistent Colors view x12
    8.71 refresh Realistic view x12
    2.87 rotate view x1
    Notes:
    Raw Data
    21.734 16.816 17.172 update previous version file
    4.805 4.547 4.641 opening and loading the custom template
    18.027 17.031 17.352 creating the floors levels and grids
    33.672 32.535 32.562 creating a group of walls and doors
    61.898 60.172 60.430 modifying the group by adding a curtain wall
    20.535 17.445 17.773 creating the exterior curtain wall
    14.000 13.402 13.359 creating the sections
    6.387 6.230 6.430 changing the curtain wall panel type
    15.941 14.711 15.203 creating area plans
    2.754 2.543 2.758 creating and applying view template
    88.980 87.141 86.898 export all views as PNGs at 300 dpi
    138.965 138.348 138.609 export all views as DWFs
    221.527 219.684 220.578 export all views as DWGs
    113.746 113.246 113.906 print all views as vector
    135.770 135.359 135.648 print all views as raster
    143.973 144.102 144.477 render
    7.082 7.039 6.930 refresh Hidden Line view x12
    7.113 7.133 7.031 refresh Consistent Colors view x12
    8.766 8.695 8.664 refresh Realistic view x12
    2.926 2.875 2.812 rotate view x1
    TEST CONDITIONS:
    Mfr: VMware, Inc.
    Model: VMware Virtual Platform
    OS: Microsoft Windows 10 Enterprise64 64-bit
    CPU: Intel(R) Xeon(R) CPU E5-2670 v3 @ 2.30GHz Intel(R) Xeon(R) CPU E5-2670 v3 @ 2.30GHz
    Max Clock Speed: Ghz
    Number of Processors: 2 2
    Number of Logical Processors: 2 2
    Total Physical Memory: 16GB @ Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: VMware Virtual disk SCSI Disk Device
    Graphics Card: NVIDIA GRID M60-2Q
    Graphics RAM: 2GB
    Driver version: 10.18.13.6256
    Graphics Card: Citrix Display Only Adapter
    Graphics RAM: 0GB
    Driver version: 1.1.1.1
    Graphics Card: VMware SVGA 3D
    Graphics RAM: 0.375GB
    Driver version: 8.15.1.33
    Screen Resolution: 1536 x864 x32bit @ 59 Hz
  2. #22
    Junior Member bmccallum's Avatar
    December 10, 2010
    Calgary, Alberta
    35
    10:35 PM
    RVT 2017 Simplified on Citrix XenDesktop
    Testing our Citrix environment. First of a few results.
    Code:
     RVT 2017 - Simplified set - 2017.02.14 @ 19.38.56 on DESKTOP04
         RevitForum.org
         8.68   opening and loading the custom template
        13.77   creating the floors levels and grids
        26.22   creating a group of walls and doors
        46.38   modifying the group by adding a curtain wall
        14.23   creating the exterior curtain wall
         9.56   creating the sections
         4.79   changing the curtain wall panel type
        11.25   creating area plans
         1.76   creating and applying view template
       136.64   TOTAL
     Graphics benchmark
         5.76   refresh Hidden Line view x12
         5.74   refresh Consistent Colors view x12
         7.44   refresh Realistic view x12
         2.27   rotate view x1
     Notes:
     TEST CONDITIONS:
     Mfr: Xen
     Model: HVM domU
     CPU: Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
     Number of Processors: 4 4
     Number of Logical Processors: 4 4
     Total Physical Memory: 32GB @ 18756 18756Mhz
     Drive Model: QEMU HARDDISK ATA Device
     Graphics RAM: 0GB
     Driver version: 1.1.1.1001
     Graphics Card: NVIDIA GRID M60-1Q
     Graphics RAM: 1GB
     Driver version: 21.21.13.6917
     Screen Resolution:  1680x 1050x32bit @  59Hz
    Still some work to do on updates, service packs, etc.
  3. #23
    November 12, 2014
    09:35 PM
    RVT 2017 - Standard set - 2017.02.16 @ 13.25.48 on BEN
    RevitForum.org
    Run on Autodesk Revit 2017.2
    Update
    11.47 update previous version file
    3.24 opening and loading the custom template
    11.04 creating the floors levels and grids
    20.10 creating a group of walls and doors
    37.07 modifying the group by adding a curtain wall
    12.43 creating the exterior curtain wall
    8.75 creating the sections
    4.21 changing the curtain wall panel type
    10.05 creating area plans
    1.50 creating and applying view template
    108.39 TOTAL
    Export benchmark
    63.67 export all views as PNGs at 300 dpi
    50.34 export all views as DWFs
    102.45 export all views as DWGs
    69.08 print all views as vector *
    106.67 print all views as raster *
    Notes:
    Render benchmark
    84.98 render
    Graphics benchmark
    5.28 refresh Hidden Line view x12
    5.08 refresh Consistent Colors view x12
    6.26 refresh Realistic view x12
    1.84 rotate view x1
    Notes:
    Raw Data
    11.859 11.184 11.356 update previous version file
    3.539 3.117 3.051 opening and loading the custom template
    11.613 10.867 10.652 creating the floors levels and grids
    19.894 20.332 20.082 creating a group of walls and doors
    37.109 36.902 37.211 modifying the group by adding a curtain wall
    12.551 12.398 12.332 creating the exterior curtain wall
    8.863 8.644 8.746 creating the sections
    4.168 4.184 4.266 changing the curtain wall panel type
    10.375 10.098 9.676 creating area plans
    1.492 1.449 1.570 creating and applying view template
    64.750 63.188 63.070 export all views as PNGs at 300 dpi
    50.422 50.547 50.039 export all views as DWFs
    103.887 103.297 100.168 export all views as DWGs
    71.273 68.137 67.820 print all views as vector
    108.094 105.996 105.934 print all views as raster
    85.133 83.906 85.894 render
    5.617 5.078 5.144 refresh Hidden Line view x12
    5.070 5.062 5.117 refresh Consistent Colors view x12
    6.324 6.219 6.223 refresh Realistic view x12
    1.812 1.906 1.801 rotate view x1
    TEST CONDITIONS:
    Mfr: ASUS
    Model: All Series
    CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
    Max Clock Speed: 3.401Ghz
    Total Physical Memory: 32GB @ 1600 1600 1600 1600Mhz
    Drive Model: Samsung SSD 850 EVO 500GB
    Graphics Card: NVIDIA GeForce GTX 1070
    Graphics RAM: 3.9990234375GB
    Driver version: 21.21.13.7653
  4. #24
    December 10, 2010
    Calgary, Alberta
    35
    10:35 PM
    RVT 2017 Standard on Citrix XenDesktop
    Okay, back with some more testing. Had to rebuild part of the Citrix environment due to a bug in the latest version.
    Still need to update to 2017.1 (.2?) and install some other apps but the platform seems to be ready.
    Code:
     RVT 2017 - Standard set - 2017.02.21 @ 16.07.23 on EDM-NEXT-VDI06
         RevitForum.org
     Run on Autodesk Revit 2017.0.3 Security Fix
     Update
        15.41   update previous version file
         4.01   opening and loading the custom template
        14.76   creating the floors levels and grids
        27.37   creating a group of walls and doors
        46.88   modifying the group by adding a curtain wall
        17.26   creating the exterior curtain wall
        10.60   creating the sections
         5.43   changing the curtain wall panel type
        13.01   creating area plans
         1.85   creating and applying view template
       141.17   TOTAL
     Export benchmark
        75.30   export all views as PNGs at 300 dpi
       111.71   export all views as DWFs
       193.06   export all views as DWGs
        91.03   print all views as vector *
       115.38   print all views as raster *
     Notes:
     Render benchmark
        69.87   render
     Graphics benchmark
         8.11   refresh Hidden Line view x12
         7.79   refresh Consistent Colors view x12
         9.16   refresh Realistic view x12
         7.58   rotate view x1
     Notes:
     Raw Data
       16.238   14.980   15.023   update previous version file
        4.121    4.090    3.816   opening and loading the custom template
       14.410   13.422   16.457   creating the floors levels and grids
       27.750   25.473   28.887   creating a group of walls and doors
       47.414   45.266   47.945   modifying the group by adding a curtain wall
       16.973   14.770   20.047   creating the exterior curtain wall
       10.348   10.637   10.828   creating the sections
        5.098    4.941    6.254   changing the curtain wall panel type
       12.941   11.742   14.348   creating area plans
        1.840    1.820    1.902   creating and applying view template
       74.676   76.227   74.992   export all views as PNGs at 300 dpi
      112.496  111.566  111.074   export all views as DWFs
      192.840  195.144  191.203   export all views as DWGs
       90.719   92.199   90.180   print all views as vector
      113.844  116.652  115.633   print all views as raster
       76.109   65.793   67.703   render
        6.500    8.148    9.680   refresh Hidden Line view x12
        6.523    6.566   10.270   refresh Consistent Colors view x12
        8.031    8.273   11.168   refresh Realistic view x12
        3.371    9.199   10.156   rotate view x1
     TEST CONDITIONS:
     Mfr: Xen
     Model: HVM domU
     Graphics RAM: 1GB
     Graphics RAM: 0GB
     Screen Resolution: 1680 x1770 x32bit @ 59 Hz
  5. #25
    11,039
    11:35 PM
    Hey Bruce! Decent setup you got there. Been doing a lot of virtualization down here as well.
    If you arent on 2017.1, upgrade ASAP and rerun. I saw a decent different (better) numbers wise, in my 2017.1 benchmarks over 2017...
    The M60 is a HOSS of a card.
  6. #26
    December 10, 2010
    Calgary, Alberta
    35
    10:35 PM
    Thanks Aaron, we tried not to cut corners. It's quite a beast.
    I'm doing some local testing on the Citrix workstations today, including upgrading to 2017.2, and will test again when that's done.
    What about the desktop app? I think I want to remove it from the machine image and manually manage the downloads/updates of apps. Any special steps we need to take when removing the desktop from image?
  7. #27
    December 10, 2010
    Calgary, Alberta
    35
    10:35 PM
    RVT 2017 Standard on Citrix XenDesktop w/ Revit 2017.2
    2017.2 installed and updated extensions, etc.
    This is still the Standard test. Will post an Expanded result next.
    Code:
     RVT 2017 - Standard set - 2017.02.22 @ 09.20.57 on DESKTOP03
         RevitForum.org
     Update
        14.91   update previous version file
         4.05   opening and loading the custom template
        15.07   creating the floors levels and grids
        26.84   creating a group of walls and doors
        45.60   modifying the group by adding a curtain wall
        15.30   creating the exterior curtain wall
        10.33   creating the sections
         5.25   changing the curtain wall panel type
        12.70   creating area plans
         1.94   creating and applying view template
       137.08   TOTAL
     Export benchmark
        76.17   export all views as PNGs at 300 dpi
        59.61   export all views as DWFs
       122.39   export all views as DWGs
     27672.80   print all views as vector *
       115.48   print all views as raster *
     Notes:
     Render benchmark
        68.91   render
     Graphics benchmark
         6.15   refresh Hidden Line view x12
         6.16   refresh Consistent Colors view x12
         7.91   refresh Realistic view x12
         3.91   rotate view x1
     Notes:
     Raw Data
       15.633   14.633   14.453   update previous version file
        4.125    4.004    4.016   opening and loading the custom template
       16.324   14.344   14.551   creating the floors levels and grids
       28.352   25.785   26.379   creating a group of walls and doors
       46.410   45.227   45.148   modifying the group by adding a curtain wall
       17.254   14.551   14.090   creating the exterior curtain wall
       10.238   10.203   10.559   creating the sections
        5.500    4.965    5.289   changing the curtain wall panel type
       12.336   13.039   12.734   creating area plans
        1.934    1.852    2.035   creating and applying view template
       75.578   75.297   77.633   export all views as PNGs at 300 dpi
       59.711   59.238   59.883   export all views as DWFs
      128.121  119.715  119.324   export all views as DWGs
    82874.453   72.477   71.469   print all views as vector
      114.426  118.184  113.816   print all views as raster
       71.207   69.836   65.676   render
        6.055    6.109    6.285   refresh Hidden Line view x12
        6.098    6.141    6.230   refresh Consistent Colors view x12
        7.535    7.617    8.578   refresh Realistic view x12
        2.902    5.938    2.894   rotate view x1
     TEST CONDITIONS:
     Mfr: Xen
     Model: HVM domU
     Graphics RAM: 1GB
     Graphics RAM: 0GB
  8. #28
    Rotterdam, South Holland
    3,071
    05:35 AM
    Quote Originally Posted by bmccallum View Post
    Bruce, good call on getting rid of the Totally Useless Redundant Downloader. As far as I have found all the 2016 & 2017 products have allowed you to unselect ADA when building a deployment, but you can also remove it after the fact. Just edit your deployment INI, and look for the Install Execute & UI Sequence section, which will have three lines starting with EXE_SEQUENCE=, INSTALL_SEQUENCE= & UI_SEQUENCE=. On each line there will be a single ;ADSKAPP reference to delete. Uninstalling is a little trickier, as there is no Uninstall GUID, there is a uninstall EXE that is part of the install. But maybe you haven't rolled out 2017 yet so revising the deployment is all you need?
    Gordon
  9. #29
    December 10, 2010
    Calgary, Alberta
    35
    10:35 PM
    Hey Gordon, thanks for the reply. We're deploying on Citrix so no deployment package was created. Instead, we've configured a master image that each VM is built from each time they're restarted. We plan to use snapshots to test new packages as they're released and deploy those packages after they're tested.
    We are currently testing a simple uninstall of the desktop app to see if it holds. Bye-bya ADA.
    New packages will be downloaded on a laptop and copied to the shared folder for installation on the master image.
    _Bruce
  10. #30
    December 10, 2010
    Calgary, Alberta
    35
    10:35 PM
    Is anyone tracking these results and comparing configurations?
  1. RFO Benchmark v3
    Last Post: August 28th, 2017, 01:18 AM
  2. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  3. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
