Please post your RFOBenchmark V3 results for the 2017 products here.
Comments and suggestions should be made in the RFOBenchmark v3 thread. The download is there too.
Thanks!
Gordon
This is my standard RFO 2017 test:
RVT 2017 - Standard set - 2016.10.18 @ 22.47.51 on LAPTOP-F4TBSSEJ
RFO Benchmark v3.0 (build 17.10.2016)
RevitForum.org
Run on Autodesk Revit 2017 SP1
__________________________________________________ _______________
Update
13.97 update previous version file
Model creation benchmark
4.40 opening and loading the custom template
19.59 creating the floors levels and grids
28.67 creating a group of walls and doors
43.50 modifying the group by adding a curtain wall
17.17 creating the exterior curtain wall
13.02 creating the sections
5.34 changing the curtain wall panel type
14.20 creating area plans
1.89 creating and applying view template
147.78 TOTAL
Export benchmark
86.70 export all views as PNGs at 300 dpi
107.27 export all views as DWFs
177.75 export all views as DWGs
98.64 print all views as vector *
125.85 print all views as raster *
Notes:
* Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
Render benchmark
92.80 render
Graphics benchmark
5.53 refresh Hidden Line view x12
5.52 refresh Consistent Colors view x12
6.79 refresh Realistic view x12
4.04 rotate view x1
Notes:
Raw Data
13.602 14.094 14.227 update previous version file
3.828 4.711 4.664 opening and loading the custom template
16.211 21.578 20.977 creating the floors levels and grids
25.461 29.367 31.188 creating a group of walls and doors
41.570 44.148 44.773 modifying the group by adding a curtain wall
14.648 18.305 18.570 creating the exterior curtain wall
12.727 13.352 12.977 creating the sections
4.992 5.664 5.372 changing the curtain wall panel type
13.242 15.586 13.783 creating area plans
1.961 2.086 1.633 creating and applying view template
86.555 86.586 86.957 export all views as PNGs at 300 dpi
107.477 106.836 107.498 export all views as DWFs
179.531 177.844 175.871 export all views as DWGs
98.539 97.945 99.424 print all views as vector
131.422 130.414 115.719 print all views as raster
94.492 93.477 90.446 render
5.680 5.414 5.504 refresh Hidden Line view x12
5.469 5.539 5.566 refresh Consistent Colors view x12
6.812 6.750 6.793 refresh Realistic view x12
4.023 4.164 3.932 rotate view x1
TEST CONDITIONS:
Mfr: LENOVO
Model: 80NV
OS: Microsoft Windows 10 Home64-bit
CPU: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
Max Clock Speed: 2.601Ghz
Number of Processors: 4
Total Physical Memory: 16GB @ 2133 2133Mhz
RVT 2017 - Standard set - 2016.10.20 @ 09.30.21 on 091006-02
RevitForum.org
Run on Autodesk Revit 2017.1
Update
14.18 update previous version file
2.91 opening and loading the custom template
11.01 creating the floors levels and grids
28.74 creating a group of walls and doors
61.67 modifying the group by adding a curtain wall
18.12 creating the exterior curtain wall
9.86 creating the sections
5.79 changing the curtain wall panel type
11.30 creating area plans
1.83 creating and applying view template
151.23 TOTAL
Export benchmark
99.89 export all views as PNGs at 300 dpi
82.01 export all views as DWFs
166.79 export all views as DWGs
95.50 print all views as vector *
146.07 print all views as raster *
Notes:
Render benchmark
131.17 render
Graphics benchmark
0.08 refresh Hidden Line view x12
0.05 refresh Consistent Colors view x12
0.05 refresh Realistic view x12
1.66 rotate view x1
Notes:
Raw Data
15.992 13.223 13.324 update previous version file
3.254 2.723 2.742 opening and loading the custom template
12.516 10.461 10.039 creating the floors levels and grids
30.340 27.770 28.121 creating a group of walls and doors
61.766 60.730 62.508 modifying the group by adding a curtain wall
18.113 17.207 19.055 creating the exterior curtain wall
10.973 9.121 9.480 creating the sections
6.438 5.340 5.598 changing the curtain wall panel type
13.418 10.207 10.266 creating area plans
1.871 2.047 1.582 creating and applying view template
97.590 103.090 99.004 export all views as PNGs at 300 dpi
80.305 81.707 84.020 export all views as DWFs
169.109 167.523 163.734 export all views as DWGs
94.809 95.856 95.840 print all views as vector
144.555 149.113 144.527 print all views as raster
127.172 134.508 131.836 render
0.066 0.078 0.082 refresh Hidden Line view x12
0.047 0.051 0.055 refresh Consistent Colors view x12
0.051 0.055 0.059 refresh Realistic view x12
1.637 1.582 1.770 rotate view x1
TEST CONDITIONS:
Mfr: System manufacturer
Model: System Product Name
OS: Microsoft Windows 7 Professional 64-bit
CPU: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
Max Clock Speed: 3.201Ghz
Total Physical Memory: 16GB @ Mhz
Drive Type: local Disk (NTFS)
Drive Model: Samsung SSD 840 EVO 250GB ATA Device
Graphics Card: AMD Radeon HD 5800 Series
Graphics RAM: 1GB
Driver version: 15.200.1046.0
Screen Resolution: 1920x1200x32bit @ 60Hz
Code:RVT 2017 - Standard set - 2016.11.18 @ 18.00.02 on ZBOOKG3 RFO Benchmark v3.0 (build 17.10.2016) RevitForum.org All times are in seconds, lower is better. Run on Autodesk Revit 2017.1 _________________________________________________________________ Update 12.16 update previous version file _________________________________________________________________ Model creation benchmark 3.23 opening and loading the custom template 13.06 creating the floors levels and grids 22.71 creating a group of walls and doors 41.09 modifying the group by adding a curtain wall 13.33 creating the exterior curtain wall 10.80 creating the sections 4.38 changing the curtain wall panel type 12.10 creating area plans 1.45 creating and applying view template 122.15 TOTAL _________________________________________________________________ Export benchmark 74.91 export all views as PNGs at 300 dpi 55.32 export all views as DWFs 106.02 export all views as DWGs 64.85 print all views as vector * 112.75 print all views as raster * Notes: * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed. _________________________________________________________________ Render benchmark 99.73 render _________________________________________________________________ Graphics benchmark 5.82 refresh Hidden Line view x12 5.73 refresh Consistent Colors view x12 7.12 refresh Realistic view x12 3.09 rotate view x1 Notes: Graphics benchmark measures the entire graphics stack, which includes CPU and memory. To meaningfully compare graphics cards, test all cards in the same machine and use the 'Graphics - expanded' benchmark. Raw Data 13.062 11.750 11.672 update previous version file 3.223 3.227 3.242 opening and loading the custom template 13.512 12.797 12.859 creating the floors levels and grids 23.070 22.656 22.398 creating a group of walls and doors 41.465 40.953 40.852 modifying the group by adding a curtain wall 13.574 13.414 13.000 creating the exterior curtain wall 10.773 10.938 10.680 creating the sections 4.434 4.445 4.266 changing the curtain wall panel type 12.125 12.109 12.062 creating area plans 1.438 1.445 1.469 creating and applying view template 74.980 74.695 75.055 export all views as PNGs at 300 dpi 55.273 56.203 54.469 export all views as DWFs 107.797 104.922 105.328 export all views as DWGs 64.773 64.766 65.000 print all views as vector 112.422 112.234 113.594 print all views as raster 109.508 94.984 94.711 render 5.852 5.812 5.805 refresh Hidden Line view x12 5.719 5.781 5.688 refresh Consistent Colors view x12 7.109 7.172 7.070 refresh Realistic view x12 3.039 3.133 3.094 rotate view x1 TEST CONDITIONS: _______________________________________________________ Mfr: HP Model: HP ZBook 15 G3 OS: Microsoft Windows 7 Professional 64-bit _______________________________________________________ CPU: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz Max Clock Speed: 2.601Ghz Number of Processors: 4 Number of Logical Processors: 8 Total Physical Memory: 16GB @ Mhz _______________________________________________________ Drive Type: local Disk (NTFS) Drive Model: NVMe THNSN5512GPU7 TO SCSI Disk Device _______________________________________________________ Graphics Card: NVIDIA Quadro M1000M Graphics RAM: 2GB Driver version: 10.18.13.5649 Graphics Card: Intel(R) HD Graphics 530 Graphics RAM: 1GB Driver version: 20.19.15.4483 _______________________________________________________ Screen Resolution: xx32bit @ Hz
RVT 2017 - Standard set - 2016.11.18 @ 21.52.23 on TOMEK-LAPTOP
RevitForum.org
Run on Autodesk Revit 2017 SP2
Update
14.72 update previous version file
3.85 opening and loading the custom template
15.08 creating the floors levels and grids
25.56 creating a group of walls and doors
43.45 modifying the group by adding a curtain wall
15.78 creating the exterior curtain wall
11.57 creating the sections
5.56 changing the curtain wall panel type
12.72 creating area plans
1.74 creating and applying view template
135.31 TOTAL
Export benchmark
78.87 export all views as PNGs at 300 dpi
153.57 export all views as DWFs
173.16 export all views as DWGs
86.90 print all views as vector *
116.38 print all views as raster *
Notes:
Render benchmark
193.10 render
Graphics benchmark
6.86 refresh Hidden Line view x12
6.77 refresh Consistent Colors view x12
8.05 refresh Realistic view x12
4.75 rotate view x1
Notes:
Raw Data
13.586 16.445 14.133 update previous version file
3.781 3.875 3.883 opening and loading the custom template
14.914 15.125 15.203 creating the floors levels and grids
25.719 24.930 26.039 creating a group of walls and doors
43.602 43.328 43.422 modifying the group by adding a curtain wall
15.930 15.742 15.664 creating the exterior curtain wall
11.664 11.422 11.633 creating the sections
5.523 5.516 5.641 changing the curtain wall panel type
12.695 12.805 12.648 creating area plans
1.734 1.773 1.727 creating and applying view template
77.797 79.977 78.844 export all views as PNGs at 300 dpi
153.852 156.305 150.562 export all views as DWFs
174.461 173.469 171.547 export all views as DWGs
86.648 87.688 86.367 print all views as vector
115.922 118.367 114.852 print all views as raster
212.234 182.609 184.445 render
6.969 6.914 6.711 refresh Hidden Line view x12
6.617 6.789 6.891 refresh Consistent Colors view x12
7.906 8.242 8.016 refresh Realistic view x12
5.180 4.906 4.156 rotate view x1
TEST CONDITIONS:
Mfr: Acer
Model: Aspire VN7-591G
CPU: Intel(R) Core(TM) i5-4210H CPU @ 2.90GHz
Max Clock Speed: 2.901Ghz
Number of Processors: 2
Number of Logical Processors: 4
Total Physical Memory: 8GB @ 1600Mhz
Drive Model: KINGSTON SM2280S3120G
Graphics Card: NVIDIA GeForce GTX 860M
Graphics RAM: 2GB
Driver version: 21.21.13.6909
Graphics Card: Intel(R) HD Graphics 4600
Graphics RAM: 1GB
Driver version: 10.18.15.4248
Screen Resolution: 1920x 1200x32bit @ 59Hz
Code:RVT 2017 - Standard set - 2016.11.18 @ 08.45.12 on I7-4770WS RFO Benchmark v3.0 (build 17.10.2016) RevitForum.org All times are in seconds, lower is better. Run on Autodesk Revit 2017.1 _________________________________________________________________ Update 12.18 update previous version file _________________________________________________________________ Model creation benchmark 3.43 opening and loading the custom template 11.68 creating the floors levels and grids 21.04 creating a group of walls and doors 35.78 modifying the group by adding a curtain wall 13.88 creating the exterior curtain wall 10.14 creating the sections 4.57 changing the curtain wall panel type 11.17 creating area plans 1.61 creating and applying view template 113.30 TOTAL _________________________________________________________________ Export benchmark 69.18 export all views as PNGs at 300 dpi 49.03 export all views as DWFs 113.59 export all views as DWGs 81.35 print all views as vector * 121.44 print all views as raster * Notes: * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed. _________________________________________________________________ Render benchmark 84.29 render _________________________________________________________________ Graphics benchmark 5.26 refresh Hidden Line view x12 5.30 refresh Consistent Colors view x12 6.36 refresh Realistic view x12 2.45 rotate view x1 Notes: Graphics benchmark measures the entire graphics stack, which includes CPU and memory. To meaningfully compare graphics cards, test all cards in the same machine and use the 'Graphics - expanded' benchmark. Raw Data 13.066 11.727 11.746 update previous version file 3.445 3.246 3.594 opening and loading the custom template 11.447 11.906 11.688 creating the floors levels and grids 20.957 21.070 21.078 creating a group of walls and doors 36.238 35.262 35.852 modifying the group by adding a curtain wall 13.980 13.797 13.867 creating the exterior curtain wall 10.031 10.156 10.227 creating the sections 4.529 4.594 4.598 changing the curtain wall panel type 11.162 11.094 11.266 creating area plans 1.572 1.644 1.613 creating and applying view template 69.467 68.953 69.113 export all views as PNGs at 300 dpi 49.514 48.711 48.856 export all views as DWFs 113.576 113.215 113.969 export all views as DWGs 81.641 80.934 81.469 print all views as vector 121.434 121.394 121.500 print all views as raster 80.164 80.207 92.484 render 5.262 5.246 5.281 refresh Hidden Line view x12 5.328 5.250 5.336 refresh Consistent Colors view x12 6.387 6.332 6.363 refresh Realistic view x12 2.500 2.445 2.391 rotate view x1 TEST CONDITIONS: _______________________________________________________ Mfr: To Be Filled By O.E.M. Model: To Be Filled By O.E.M. OS: Microsoft Windows 10 Pro64-bit _______________________________________________________ CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz Max Clock Speed: 3.401Ghz Number of Processors: 4 Number of Logical Processors: 8 Total Physical Memory: 16GB @ 1333 1333Mhz _______________________________________________________ Drive Type: local Disk (NTFS) Drive Model: Samsung SSD 840 EVO 250GB _______________________________________________________ Graphics Card: NVIDIA GeForce GTX 760 Graphics RAM: 2GB Driver version: 21.21.13.7270 Graphics Card: Intel(R) HD Graphics 4600 Graphics RAM: 1GB Driver version: 20.19.15.4531 _______________________________________________________ Screen Resolution: 2560 1600x1440 1200x32bit @ 59 60Hz
My main workhouse (laptop), running on 2560x1440:
EDIT: Previous benchmark results were a mistake, because of an error. This is now the correct run, using v3.Originally Posted by RFO Benchmark v3.0
RVT 2017 - Standard set - 2016.11.16 @ 08.32.59 on SEA-????-1
RevitForum.org
Update
13.13 update previous version file
2.86 opening and loading the custom template
10.01 creating the floors levels and grids
27.33 creating a group of walls and doors
58.58 modifying the group by adding a curtain wall
14.76 creating the exterior curtain wall
8.33 creating the sections
5.06 changing the curtain wall panel type
9.33 creating area plans
1.53 creating and applying view template
137.79 TOTAL
Export benchmark
87.16 export all views as PNGs at 300 dpi
81.23 export all views as DWFs
161.72 export all views as DWGs
94.02 print all views as vector *
164.69 print all views as raster *
Notes:
Render benchmark
39.07 render
Graphics benchmark
0.07 refresh Hidden Line view x12
0.04 refresh Consistent Colors view x12
0.04 refresh Realistic view x12
1.49 rotate view x1
Notes:
Raw Data
13.371 13.006 13.027 update previous version file
2.848 2.865 2.871 opening and loading the custom template
10.324 9.805 9.910 creating the floors levels and grids
27.734 27.144 27.117 creating a group of walls and doors
59.080 58.656 58.012 modifying the group by adding a curtain wall
15.049 14.625 14.609 creating the exterior curtain wall
8.373 8.348 8.273 creating the sections
5.141 4.988 5.039 changing the curtain wall panel type
9.562 9.285 9.137 creating area plans
1.557 1.469 1.551 creating and applying view template
86.455 87.199 87.824 export all views as PNGs at 300 dpi
81.336 80.719 81.637 export all views as DWFs
161.113 162.852 161.199 export all views as DWGs
93.953 94.473 93.641 print all views as vector
163.301 166.336 164.426 print all views as raster
39.363 38.770 39.078 render
0.066 0.066 0.062 refresh Hidden Line view x12
0.045 0.043 0.043 refresh Consistent Colors view x12
0.041 0.043 0.039 refresh Realistic view x12
1.482 1.418 1.562 rotate view x1
TEST CONDITIONS:
Mfr: HP
Model: ProLiant SL250s Gen8
OS: Microsoft Windows Server 2008 R2 Datacenter -bit
CPU:
Max Clock Speed: 0Ghz
Total Physical Memory: 128GB @ Mhz
Drive Model: HP LOGICAL VOLUME SCSI Disk Device
Graphics Card: Mirage Driver
Graphics RAM: 0GB
Driver version: 2.0.105.0
Graphics Card: NVIDIA Tesla M2070-Q
Graphics RAM: 3.9990234375GB
Driver version: 9.18.13.1135
Graphics Card: Matrox G200eH (HP)
Graphics RAM: 0GB
Driver version: 1.2.1.0
RVT 2017 - Standard set - 2016.11.21 @ 12.46.09 on SEA-L13-???????
RevitForum.org
Update
19.56 update previous version file
4.32 opening and loading the custom template
19.96 creating the floors levels and grids
38.71 creating a group of walls and doors
72.30 modifying the group by adding a curtain wall
23.79 creating the exterior curtain wall
17.89 creating the sections
8.26 changing the curtain wall panel type
20.35 creating area plans
2.88 creating and applying view template
208.46 TOTAL
Export benchmark
90.22 export all views as PNGs at 300 dpi
95.86 export all views as DWFs
177.55 export all views as DWGs
105.56 print all views as vector *
169.40 print all views as raster *
Notes:
Render benchmark
174.19 render
Graphics benchmark
11.28 refresh Hidden Line view x12
11.42 refresh Consistent Colors view x12
14.19 refresh Realistic view x12
3.40 rotate view x1
Notes:
Raw Data
20.574 19.074 19.023 update previous version file
4.297 4.336 4.328 opening and loading the custom template
20.098 19.840 19.930 creating the floors levels and grids
38.363 38.680 39.082 creating a group of walls and doors
76.371 70.695 69.848 modifying the group by adding a curtain wall
24.406 23.438 23.535 creating the exterior curtain wall
18.512 17.383 17.770 creating the sections
8.320 8.106 8.344 changing the curtain wall panel type
20.856 19.535 20.672 creating area plans
3.004 2.742 2.891 creating and applying view template
89.043 87.281 94.332 export all views as PNGs at 300 dpi
100.336 88.480 98.777 export all views as DWFs
178.910 169.570 184.168 export all views as DWGs
109.547 102.590 104.543 print all views as vector
176.809 164.957 166.441 print all views as raster
169.113 156.367 197.102 render
11.586 11.125 11.141 refresh Hidden Line view x12
11.098 11.148 12.000 refresh Consistent Colors view x12
13.977 13.598 14.988 refresh Realistic view x12
3.367 3.422 3.422 rotate view x1
TEST CONDITIONS:
Mfr: Dell Inc.
Model: Precision M4600
OS: Microsoft Windows 10 Enterprise64-bit
CPU: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz
Max Clock Speed: 2.401Ghz
Total Physical Memory: 16GB @ 1333 1333 1333 1333Mhz
Drive Model: Samsung SSD 840 Series
Graphics Card: NVIDIA Quadro 2000M
Graphics RAM: 2GB
Driver version: 9.18.13.3221
Graphics Card: Intel(R) HD Graphics 3000
Graphics RAM: 2.05859375GB
Driver version: 9.17.10.3517
Screen Resolution: 1920 1920x1080 1200x32bit @ 60 59Hz
RVT 2017 - Standard set - 2016.12.02 @ 19.03.07 on SMOKU
RevitForum.org
Run on Autodesk Revit 2017.1.1
Update
9.57 update previous version file
2.67 opening and loading the custom template
8.93 creating the floors levels and grids
16.59 creating a group of walls and doors
30.47 modifying the group by adding a curtain wall
9.41 creating the exterior curtain wall
7.02 creating the sections
3.26 changing the curtain wall panel type
8.01 creating area plans
1.13 creating and applying view template
87.49 TOTAL
Export benchmark
53.32 export all views as PNGs at 300 dpi
40.04 export all views as DWFs
110.24 export all views as DWGs
48.94 print all views as vector *
82.47 print all views as raster *
Notes:
Render benchmark
68.49 render
Graphics benchmark
4.04 refresh Hidden Line view x12
4.08 refresh Consistent Colors view x12
4.99 refresh Realistic view x12
1.53 rotate view x1
Notes:
Raw Data
9.930 9.359 9.422 update previous version file
2.680 2.680 2.656 opening and loading the custom template
9.094 8.859 8.836 creating the floors levels and grids
16.586 16.625 16.562 creating a group of walls and doors
30.539 30.492 30.383 modifying the group by adding a curtain wall
9.406 9.414 9.422 creating the exterior curtain wall
7.047 7.023 6.977 creating the sections
3.273 3.281 3.234 changing the curtain wall panel type
8.016 8.102 7.922 creating area plans
1.188 1.117 1.094 creating and applying view template
53.484 53.312 53.156 export all views as PNGs at 300 dpi
40.039 39.961 40.133 export all views as DWFs
110.234 110.297 110.180 export all views as DWGs
49.000 48.859 48.953 print all views as vector
82.445 82.414 82.539 print all views as raster
65.500 65.000 74.969 render
4.062 4.031 4.039 refresh Hidden Line view x12
4.078 4.094 4.078 refresh Consistent Colors view x12
5.008 5.008 4.953 refresh Realistic view x12
1.547 1.492 1.555 rotate view x1
TEST CONDITIONS:
CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Max Clock Speed: 4.001Ghz
Total Physical Memory: 16GB @ 3000 3000Mhz
Drive Model: Samsung SSD 850 EVO M.2 250GB
Graphics Card: NVIDIA GeForce GTX 1070
Driver version: 21.21.13.7570
