Thread: Rotation Error
    October 18, 2016
    26
    12:30 AM
    Rotation Error
    Hello evryone,
    I'm having troubles with the rotation of a simple extrusion. ( In a Metric Generic Model )
    I made this extrusion with a different centerpoint where it is supposed to rotate. and added here a reference line to make the rotation work -> see image 1
    After that I Loaded this family ( Metric Genreric Model ) in another Family ( Also Metric Generic ) .
    Here i added the Parametric parameter to make a instance of that rotation. -> image 2
    The rotation works perfectly , as demonstration i setted a rotation on 90░, 10░ and 50░.
    But as soon as i put the angle on 0░ or 180░, the model isn't centered anymore and rotates however it wants .. -> Image 5
    Any suggestions ?
    Thank you in advance !
ID:	28724   Click image for larger version.
ID:	28725   Click image for larger version.
ID:	28726   Click image for larger version.
ID:	28727   Click image for larger version.
Name:	ROT 50°ERROR.PNG
    March 21, 2013
    275
    04:30 PM
    Rotation is tricky. Try looking here:
    Simply Complex: ROTATION RIGS THAT DO NOT USE THE ANGLUAR DIMENSION
    - - - Updated - - -
    http://therevitcomplex.blogspot.com/2012/04/rotation-rigs-that-do-not-use-angluar.html
    October 18, 2016
    26
    12:30 AM
    Looks like a great help.
    I'll try it right away.
    Thank you!
    October 18, 2016
    26
    12:30 AM
    Seems like nesting the family for each movement did the trick..
  1. 3d Extrusion Rotation
    By rboaz in forum Architecture - Family Creation
    Last Post: November 23rd, 2016, 03:51 PM
  2. Duct Tee rotation
    Last Post: September 17th, 2014, 01:40 PM
  3. rotation
    By mona miller in forum Architecture - Family Creation
    Last Post: July 27th, 2014, 10:47 PM
  4. Tag Family Rotation
    By darknes15 in forum Structure - Family Creation
    Last Post: June 19th, 2014, 03:30 AM
  5. object rotation
    Last Post: April 5th, 2014, 10:19 AM
