Thread: Need help Passing Fixture Units through my Family
    December 26, 2016
    7
    05:48 PM
    Hello...I'm having trouble passing Fixture Units through families that i'm creating. I created a back to back water closet carrier, with the connectors coming in from the 3 inlets (the back end of the carrier plus each of the toilets) all set to Flow Configuration "Calculated" and Flow Direction "In". However when i go to set the my outlet parameter (by totaling the 3 inlet parameters), I have a unit of GPM...so when i go to neutralize the unit by dividing by 1, its changing my "1" to "1 CFM". so i suspect im never converting to FUs for my outlet connector to pass onto the connected pipe, and thus getting a 0 calculation on my fixture unit pipe tag. Has anyone had a similar problem and have any advice?
    1,405
    11:48 PM
    Try setting all your connectors to Fixture Units instead of Calculated. Also if you set all the connectors to Fitting the FUs will pass through automatically, but then you cant do any calculations with them in the family itself.
    Also check your piping system is set up for FUs and not flow.
  1. Fixture Units Updates after updating units in families
    By edwardsdv in forum MEP - General
    Last Post: September 21st, 2017, 09:51 PM
  2. Plumbing family - Fixture Units
    By jawatts4 in forum MEP - Family Creation
    Last Post: May 27th, 2016, 01:01 PM
  3. Fixture Units Below 1?
    By JPREng in forum MEP - General
    Last Post: March 14th, 2016, 12:33 PM
  4. Fixture Units
    By Croat in forum MEP - General
    Last Post: September 18th, 2015, 12:24 PM
  5. Fixture units
    By notgotaclue in forum MEP - General
    Last Post: April 22nd, 2014, 11:24 PM
