Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Exporting and Importing from Excel
    November 27, 2012
    633
    10:34 PM
    we have load of standard excel schedules we use (before revit) which i have produced in revit now.
    I want to create a dynamo script that uses are original excel sheets to push info into revit and vice versa
    is it possible and will I have to create a new script for each catorgory? ie Air termial schuedle (using catogory node in dynamo)
    Cheers
    6,389
    05:34 PM
    You can use one Dynamo graph for all of your processing but you will need a set of nodes for each category.
    November 27, 2012
    633
    10:34 PM
    What is that. Sorry I'm new to dynamo I've not actually created anything that exports to excel yet just seen something on YouTube
    6,389
    05:34 PM
    The Anatomy of a Visual Program | The Dynamo Primer
    In Dynamo, Nodes are the objects you connect to form a Visual Program. Each Node performs an operation - sometimes that may be as simple as storing a number or it may be a more complex action such as creating or querying geometry.
    November 27, 2012
    633
    10:34 PM
    Brain wasn't in gear today. I know what a graph is DOH!
    So a new category node for each new category? Also there will be different parameters in the different categories
    6,389
    05:34 PM
    Pretty much. You will have a set of nodes for each schedule you want to process.
    Category: Air Terminal -> Extract Data -> Write Excel
    Category: HVAC Equipment -> Extract Data -> Write Excel
    The Write Excel could be combined if you are putting everything in one spreadsheet, otherwise you will need several of those as well.
    November 27, 2012
    633
    10:34 PM
    so ive created this, but i cant get it to output anything excel?
Name:	revit to excel.jpg
    November 21, 2012
    Boston, MA (USA)
    612
    10:34 PM
    In theory what you have should work. What is the output of yourList.Create and List.Transpose nodes?
    I've whipped it up again using a little DesignScriptand it works fine.
    November 27, 2012
    633
    10:34 PM
    Quote Originally Posted by amoursol View Post
    that looks abit more fancier than mine with less nodes. this is my first attempt at doing a script. i added a watch node to the nodes to you mention and it just says 'function'?
    November 21, 2012
    Boston, MA (USA)
    612
    10:34 PM
    Have you hit run? If it says function it's not parsing any data.
  1. Revit Express Tools - Schedule XL - Importing Excel into Existing Revit Schedule (?)
    By theintern in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2016, 05:00 AM
  2. Replies: 3
    Last Post: June 6th, 2015, 11:18 AM
  3. Exporting / Importing Search Sets
    By Drew in forum Coordination Tools
    Last Post: May 8th, 2015, 01:58 PM
  4. Importing Excel Files
    By Mr_Greg in forum Structure - General Questions
    Last Post: April 23rd, 2013, 08:59 PM
    Last Post: September 20th, 2012, 09:15 AM
