Results 1 to 10 of 14
Thread: Schedules - Formatting (Bold totals!)
    March 13, 2012
    79
    05:06 AM
    3 Not allowed! Not allowed!
    Given that I've been using Revit for so long and I didn't know it was possible, I thought it might help others who like a nicely formatted schedule. I apologize if this is common knowledge - I did revit training ages ago and I'm really due for a refresher. In any case:
    It always drove me nuts that I couldn't nicely format schedules in revit - bolded totals, clean lines, etc. You click on a cell, you can't change the text. You click on a header, you can change the text. The totals, you can't change. It leads to a lot of schedules that look like this:
    Now maybe that's fine in CD or for a massive + complicated door schedule, but for a simple schedule that you might be showing a client early in the design process, it's a bit clunky. What I discovered one day, somewhat by accident, was that if you select an entire column you can over-ride the text settings! When I realized that this didn't affect the Total text, I had a bit of a eureka moment: if I set the default schedule text to be the style I want for the totals (bold), I can just select all of the columns and over-ride the rest of the schedule to be normal text! Now, with some tweaks to the gridlines, it looks like this - a little better!
    (be sure to highlight your headers and reset them, otherwise they're overwritten too)
    After even more trial and error, and much frustration, I came to my final realization - when you select a column, the formatting box changes ever so slightly to be two rows rather than one. Select a bunch of columns, and it expands yet again:
    What this means is, you have a chance to change all of your row formatting! It's not immediately obvious, but if you select your linetype first and then click the border you want, you'll change the line type + weight of the schedule grid. It's deceptive, because it doesn't show lineweight. Your settings here apply to each section of the schedule that's separated by a total. In other words, the "bottom border" is the line right before the total, the middle border is the line after each schedule row, and the top border is the top border in the schedule. Additionally, if you really want a border to not show up, you have to turn it on and then off. If you have all of your columns highlighted at once, you have to ensure you get all of the settings at once. If you go back and change one column's setting, it'll over-ride everything and it's really annoying. A few tweaks later and now I have a presentation/graphic schedule that I can apply to anything:
    Perfect! A much nicer schedule for presentations, client packages, and things like quick massing studies where you want to see floor + area totals of conceptual masses. Of course, as is the nature of Revit, you can't save this as a template because of all the over-rides. So, get used to the process over over-riding the font and tweaking the borders.
    I feel stupid for not knowing this sooner, but Revit has never been the most user-friendly program. My hope is that by putting this here, others who are in the same situation will learn something. If you have any additional schedule formatting tips, please share!
    (This is for Revit 2016 and earlier - I haven't upgraded to 2017 yet so maybe some of this is fixed?)
ID:	29191   Click image for larger version.
ID:	29192   Click image for larger version.
ID:	29193   Click image for larger version.
    January 17, 2011
    2,122
    04:06 AM
    Excellent write up, thanks for sharing!!
    -TZ
    December 20, 2010
    1,151
    05:06 AM
    Absolutely beautiful!!!! been using revit tooo long not to know this.
    January 6, 2017
    11:06 AM
    JUST WANT TO SAY : THANKkkkkkkksssssssssssssssssssssssssss
    December 14, 2018
    11:06 AM
    this is great, thanks!
    December 30, 2016
    03:06 AM
    I must be missing something. I'm using Revit 2019. After you highlight a column to override the text settings, what do you do next? I can't right click, neither my formatting nor appearance box change in my schedule properties. So how do you override the text?
    3,423
    04:06 AM
    If you have access to the BILTNA conference materials, Purvi Irwin did a whole session on doing fancy stuff with schedules.
    It's titled something like "Taking Schedules to the next level"
    December 30, 2016
    03:06 AM
    Unfortunately I do not.
    March 13, 2012
    79
    05:06 AM
    Quote Originally Posted by Thumper View Post
    after you click on the column, click on the "font" button
    February 2, 2019
    06:06 AM
    I went through that
    This post is excellent, but there's one minor thing, before it works you need to discard any template applied to your schedule. The trick here is to apply a template that takes you as close as you can to the desired result, then click on template "none" and discard it. When you do that, all settings remain, they are just unlocked, that's when you can perform all operations described in the post by guitarchitect
  1. Conditional Formatting for Calculated Totals
    Last Post: March 14th, 2016, 05:30 PM
  2. Node to read totals from schedules.
    By Revitaoist in forum Dynamo BIM
    Last Post: November 20th, 2015, 07:45 AM
  3. Revit OpEd: Text Formatting with Bold and Underline
    Last Post: February 14th, 2015, 04:15 PM
  4. Stack Formatting Schedules
    By billiam in forum Architecture and General Revit Questions
    Last Post: January 21st, 2015, 02:49 AM
  5. Formatting Window Schedules
    By Alan Roberts in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2011, 03:03 AM
