Thread: Need help with Polycurve by joined curves
    June 29, 2015
    5
    01:58 AM
    Hello!
    Can someone please help me with my list. I am trying to create polycurve by joined curves. I know it is basic stuff but I could really use a push here. In the image below I red circled the problem. I would like to create polycurve from 3 joined curves but I don't know how to flatten my list in that way.
    Thanks.
    November 21, 2012
    Boston, MA (USA)
    612
    02:58 AM
    Hello Minsc,
    Use a Flatten Node and List@Level on it. You'll either need @L2 or @L3 for your case.
    June 29, 2015
    5
    01:58 AM
    Thanks a lot amoursol for your reply. I have used a flatten node as u said. Its basic stuff, but sometimes brain does not cooperate and need a little push.
  1. Sort 2 Selections of Curves to Match closest
    By irneb in forum Dynamo BIM
    Last Post: May 8th, 2015, 02:04 PM
  2. Dimensionig curves in section view
    Last Post: June 2nd, 2014, 05:42 PM
  3. Divisions between two curves corresponding to the center of the smaller one
    By equiv in forum Architecture - Family Creation
    Last Post: July 8th, 2013, 09:45 PM
  4. Massing Help - Compound Curves
    By cellophane in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 1st, 2013, 04:43 PM
  5. How to create/extract curves from surface edges?
    By oneonth3run in forum Architecture and General Revit Questions
    Last Post: January 17th, 2013, 05:35 PM
