Harlan Brumm (Autodesk Product Support) posted a great list of known issues / solutions at the Autodesk Forums.
This is a repost of the original, and all credit goes to Harlan Brumm.
Revit Architecture/Platform:
Products Keys for Revit 2011 Products
Clean Uninstall of Revit 2011 Products
Switching to pre-2010, Classic user interface
Resetting the Autodesk Revit Architecture 2011 User Interface
Materials in Revit 2011 FBX are not visible in 2010 applications
Create a custom elevation tag in Revit 2011 products
Rendering with a background image in Revit 2011 products
Revit 20 mile origin limit for imported and model geometry
Cannot tag a room in a linked Revit 2011 project
Rendering processor core limit for Revit 2011 products
Materials are not visible in a Revit view set to realistic visual style
Control workset visibility for a Revit link in the host project
Some features may not be fully supported by the video card and driver on this computer
Location for Revit 2011 KeyboardShortcuts.xml file
Revit 2011 additional render paths work differently with realistic views than with rendering
Upgrading IES lights in Revit 2011
In Revit 2011 the PANTONE Find Color field does not search for a matching color
Revit adaptive component does not appear in place a component list
Family containing filled or masking regions appear white in Revit realistic visual style
Revit on Parallels (Mac) with Windows 7 will crash when you click on the Application Menu "R".
Revit Structure:
Object data missing from 2D DWF export
Uninstalling the Autodesk Material Library 2011
Unable to place rebar in column
Using the plan rep subcategory for structural foundations
Error: Slab shape edit failed when setting the curved edge condition
Revit MEP:
Known limitations with panel schedules in Revit MEP 2011
Known limitations with conduit in Revit MEP 2011
Known limitations with cable tray in Revit MEP 2011
