Thread: Pipe Elbow Tick Sizing
    Junior Member RenChan's Avatar
    March 30, 2016
    27
    05:01 PM
    I am completely blanking on a solution to my tick size altering at different elbow angles. How can I program the tick size to stay consistent with each angle?
    The tick size parameter is currently: Fitting Outside Diameter *0.4
    Fitting Outside Diameter: Nominal Diameter *1.1
    Thank you in advance
    -RenChan
ID:	29639   Click image for larger version.
Name:	tick param.PNG
    1,405
    01:01 AM
    I usually constrain the ends of the lines to the geometry of the fitting, so that the line length is the actual width of the thing.
    If thats not required I think it is actually better/neater to not show them at all, or use fixed sized round points or short lines that are the same in every family.
    March 30, 2016
    27
    05:01 PM
    I have the tick size constrained and my company prefers to be the tick size the same size regardless of the pipe size. Right now it works like that EXCEPT it does not obey my constraints when the angle is not 90. In fact the tick size grows the larger the angle. I can't figure out how to further constrain the tick size when it should just be reading off the nominal diameter.
    January 17, 2011
    2,104
    07:01 PM
    Personally, my global solution to this is to remove the ticks altogether. I don't use them anymore for any reason. I don't even use radius elbows on single line - all mitered. Ticks are a drafting standard and while I personally think ticks do look good, It's too much trouble to try and use them in a BIM environment like Revit, so I changed my standard to better fit the way programs work in today's BIM world.
    -TZ
    March 30, 2016
    27
    05:01 PM
    My company and I prefer to see the ticks and we use radius elbows because we also do shop drawings and spools. I was just having trouble getting the tick size to obey the constraints when doing different angles. I did find the solution on another site. The parameter just needed to be: "Fitting Outside Diameter * 0.4 * tan(Angle / 2)" for the tick size.
    Thank you all for responding, I declare case closed.
    January 17, 2011
    2,104
    07:01 PM
    Quote Originally Posted by RenChan View Post
    No problem. This will most likely continue to be a nuisance unless you are using only these few fittings and no more. Since I use a lot of different fittings I had to decide on constantly manipulating things based on nothing more than an old drafting standard/preference, or make it easy. I think it's cleaner and easier to read in the longrun without fitting ticks so I won't be going back regardless. Lines, Pipe up/down, and that's it for me.
    -TZ
  1. Duct/Pipe sizing Issue
    By Abdelraouf Muhammad in forum MEP - General
    Last Post: June 21st, 2016, 09:56 AM
  2. pipe sizing in revit
    By Notgotaclue1 in forum MEP - General
    Last Post: June 15th, 2016, 03:25 PM
  3. Sizing pipe fittings
    By Danz86 in forum Dynamo BIM
    Last Post: October 20th, 2015, 10:48 AM
  4. Pipe sizing
    Last Post: September 19th, 2015, 09:38 AM
  5. Revit Pipe Sizing By Specific Values
    By gurselgunacar in forum MEP - General
    Last Post: May 14th, 2014, 10:13 AM
