Results 1 to 1 of 1
Thread: Waste Pipe Fitting - With Tee & Wye Combo
    Junior Member Theophilous's Avatar
    February 1, 2012
    Vancouver Wa.
    36
    03:09 PM
    Question Waste Pipe Fitting - With Tee & Wye Combo
    Greetings!
    It's been a long time since I've worked on Pipe Fittings. So please forgive the simple questions.
    Is it possible to have a waste/gravity fitting that can be both a tee & and wye, that I can assign to a pipe type and automatically switch between the two?
Name:	Wye & Tee Fitting.png
  1. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: July 8th, 2016, 01:56 PM
  2. pipe fitting for XYZ-like tee
    By Ning Zhou in forum MEP - Family Creation
    Last Post: July 14th, 2015, 08:43 AM
  3. Pipe Fitting Keeps dissapearing
    By JPREng in forum MEP - General
    Last Post: June 20th, 2015, 11:37 PM
  4. Pipe fitting. Who can help?
    By domsib in forum MEP - Family Creation
    Last Post: January 30th, 2015, 02:33 PM
  5. Drainage fitting/pipe
    Last Post: October 3rd, 2013, 05:48 PM
