Thread: Visibility conditional statements formulas - HELP
    July 5, 2012
    22
    10:40 AM
    Hey, there.
    How can I accomplish this? Is it possible? I looked over the "Revit formulas for "everyday" usage" post, but I'm pretty confused which one should I use to accomplish what I need.
ID:	29760   Click image for larger version.
    10,793
    06:40 AM
    You will need 8 more parameters. I use what i call *actual* parameters.
    So, C1act = and(C1, Texto a Esquerda - Offset Adapto)
    This is going to give you another problem, since you used a math sign in the parameter name (-). Youll need to take that out, for it to work. It wont gray out those parameters, but those parameters wont DO anything, since youll have the geometry (or whatever) set to C1act instead of C1.
    6,329
    07:40 AM
    You can technically use the parameters with operators in the name but you need to wrap the parameter name in brackets [parameter-name].
    C1act = and(C1, [Texto a Esquerda - Offset Adapto])
    IMO it isn't worth the headache and removing the operator from your parameter name as Aaron mentioned is the better option in the long run.
    10,793
    06:40 AM
    Great point, Chad. Thanks for clarifying. I completely forgot you can do that!
    July 5, 2012
    22
    10:40 AM
    Thank you all! It worked
  1. Conditional Schedule Formulas
    By cupraymyun in forum Tutorials, Tips & Tricks
    Last Post: December 7th, 2016, 07:41 PM
  2. Replies: 8
    Last Post: May 9th, 2014, 03:30 PM
  3. Visibility Yes/No Conditional Statement
    By Lisa in forum Architecture - Family Creation
    Last Post: February 11th, 2014, 12:29 AM
  4. Conditional statements, anyone?
    By Jaime in forum Architecture - Family Creation
    Last Post: July 30th, 2013, 02:37 PM
  5. Visibility, Formulas and the Yes/No button.
    By GabrielBlack in forum MEP - Family Creation
    Last Post: January 10th, 2013, 08:44 AM
