Thread: duct accesories level parameter
    Member Darius's Avatar
    May 6, 2013
    493
    07:22 PM
    I'm working on a project at a new company that is large with alot of fire/smoke dampers and they want the level of the parameters in a schedule this does not appear to easily done. Am i missing something
    1,402
    02:22 AM
    No, they dont report level, or room/space for some stupid reason...
    For ducts I understand why this is as they can pass through multiple rooms or levels, but this should be made available to duct and pipe accessories.
    One solution is to use Dynamo to check what room/space they are in, or check the z coordinate against level elevations, and write that into a parameter.
    Or, you could nest a small family from a category that does show level (Mech Equip) inside the duct accessory, link some params to show what the host is, and schedule those. Ive discussed this before here: https://www.revitforum.org/mep-gener...ermostats.html
    January 17, 2011
    2,068
    06:22 PM
    Multi Category schedule would work, but may require an additional Shared Parameter.
    -TZ
    1,402
    02:22 AM
    Ah yes, that does work.. but then you dont have access to any of the System parameters.
    It amazes me how awkward and inconsistent access to data is in revit, considering it is just an sql database underneath.
  1. Updated Project parameter to Nested Accesories.
    By swapr78 in forum MEP - General
    Last Post: March 14th, 2017, 04:48 AM
  2. Duct Size Parameter
    By evan.dodds in forum MEP - General
    Last Post: June 22nd, 2016, 03:40 PM
  3. Can anyone module Bus duct? With correct category and its parameter.
    By veeranna.guggari13 in forum MEP - General
    Last Post: January 20th, 2016, 01:07 PM
  4. Problems using ROUND() function with Duct Size parameter
    By tzframpton in forum MEP - Family Creation
    Last Post: November 26th, 2015, 04:11 PM
  5. Duct Size vs Length parameter
    Last Post: November 26th, 2014, 06:58 PM
