Thread: Problem: Revit can't find linked dwg anymore
    78
    01:06 PM
    Hi
    Revit 2012 can't find a linked dwg anymore. When I try to reload it, Revit says the file doesn't exist. There is an other linked dwg in the same folder, which still loads fine.
    Anyone had this issue before?
    -rpict
    August 29, 2011
    Ottawa, Canada
    4
    07:06 AM
    Have you moved the file that it says doesn't exist? Have you tried using "Reload from" and selecting the file in question?
    78
    01:06 PM
    Quote Originally Posted by Teqqi View Post
    Sorry for not beeing clear enough. the file is still at the same place and opens fine in autocad.
    Yes, I tried this several times. I also copied the file to another place, no luck. I renamed it, still not found.
    Detaching and reattaching doesn't work neither.
    There is an old thread on AUGI focussing the same issue. http://forums.augi.com/showthread.php?t=111157
    Is somebody somewhere with a slotion for this out there?
    -rpict
    August 29, 2011
    Ottawa, Canada
    4
    07:06 AM
    Have you tried this:
    1) Detach the file (remove it completely from Revit project)
    2) Save & Close the project
    3) Re-open the project with the Audit option checked to check the file for errors.
    4) Re-attach the problematic DWG file.
    You might want to run an audit on the DWG file in AutoCAD as well before re-attaching it in Revit.
    78
    01:06 PM
    Hi Teqqi
    thanks for your suggestions. They brought me on the right track.
    Here is the way I did to solve the problem in a acceptable amount of time:
    1) make view templates for the graphical overrides of the imported dwg (Overrides import)
    2) remove the file from the project
    3) save under new name
    4) reopen the project and Link CAD the same dwg file
    5) apply the view template for graphical overrides
    6) check all views, if you imported to all views
    7) redo dimensions, if there were any connecting the linked dwg with the model
    It's a bit a miracle why this happens. In older versions of the Revit file the same dwg just loads fine.
    I guess it's a corruption in the Revit file itself.
    -rpict
  1. How to search/find a family type (with a particular parameter) in your library?
    Last Post: July 12th, 2011, 07:48 PM
  2. Autodesk Find and Replace
    Last Post: July 12th, 2011, 04:45 PM
  3. Where can I find families for plumbing fittings?
    By maxesicu in forum MEP - Family Creation
    Last Post: July 1st, 2011, 11:15 PM
  4. Forum mobile does not stay selected anymore
    By Rick Moore in forum Forum Suggestions and Feedback
    Last Post: April 29th, 2011, 04:04 PM
  5. You will find the use of it...
    By jbenoit44 in forum Tutorials, Tips & Tricks
    Last Post: February 9th, 2011, 03:44 PM
