Thread: Nested Family
    October 18, 2016
    26
    05:54 AM
    Nested Family
    I'm struggeling with some of my models.
    I have this model ( SPY ON ) which is a nested family.
    This contains : The family "ROTATION" and a extrusion of a ceiling pot.
    In ROTATION -> Family 6 , in Family 6 -> TILT , in TILT you can find the last family : LAMP
    Now here is my problem: I added my Photometric data to the family "LAMP" so it Rotates and tilts allong the rest of the file .
    And also the "tube" is drewn in here.
    IN the Nested Family : RSen_63_LF_FB_Luminaire - SPY ON_deltalight, you can change the color of the tube and the housing ( Parameters are instance )
    But I have to make it possible that the client can select a color in the Type catalog, which causes that the .IES files that are linked to the Photometric data have to be change as well.
    But when i change them and set them to another type, all the other types are changed as well ..
    Does anyone have an idea on how to solve this ?
    Thank you in advance!
    1,402
    06:54 AM
    Whoa.. that was like the movie Inception...
    How many levels of families in families??
    Try making a rotation system in the main family, that moves a reference line to whatever angle you want, then attach the 3D model to it, and a light source in the main family controlled by a parameter.
    If that doesnt work then put the light source in just the first level of nested family. Make a type in the nested family for each light source you want to use. Then in the main family use a 'Family Type' (Label) parameter to select light source type in the main family.
    October 18, 2016
    26
    05:54 AM
    Hi Joseph,
    Thanks for the quick reaction!
    The Family-ception is because it rotates in 2 ways :It Tilts and it rotates ( Each rotation requires 2 familes, 1 to set the rotation and one to make the rotaton from a certain place )
    -> The tilting part may not tilt the Bottem part , so it has to be in a different family
    -> Rotation part has to be evrything together
    --> The Families "TILT" and "Rotate" already contains a parameter controlled reference line, there parameters are also set to instances so I can control them in the main family ( RSen_63_... )
    (Sorry , this is getting complicated )
    And also tried this to make a type of the lightsource.. But it doesn't change the end-result
    It doesn't change a thing
    Is it maybe my way of making family types ?
  1. Family Editor changes 2012 - 2014. Constraint to nested family broken.
    By Duncan in forum Architecture - Family Creation
    Last Post: May 4th, 2017, 11:35 PM
    Last Post: March 16th, 2017, 04:15 AM
  3. Face Based Family with only a Void Nested into a Generic Model Family
    Last Post: October 18th, 2016, 03:12 PM
  4. Replies: 5
    Last Post: November 13th, 2014, 09:00 PM
  5. Replies: 5
    Last Post: April 2nd, 2014, 08:59 PM
