Thread: White as Grey in Elevation - Drywall Material Issue
    April 24, 2017
    02:59 PM
    Question White as Grey in Elevation - Drywall Material Issue
    Hello everyone,
    I have a drywall material and in elevation (shaded) it shows as true white. When I duplicate that EXACT material OR create a NEW material with the EXACT properties, it shows as a shaded grey. I can even place that duplicated material on the same wall family and it turns grey. I wish it to be white. There are no filters in my view.
    I can change the sun setting to 100% and make everything white however it does not answer the question as why one material is not effected by sun setting and one is, when the ONLY difference is the name. Why does drywall material stay white in shaded mode?
    Thank you!
    Attached Thumbnails Attached Thumbnails door-q-3.PNG   2.jpg   door_question 4.PNG
    6,287
    05:59 PM
    Do you have some sort of override in the view - either a filter or element override?
    April 24, 2017
    02:59 PM
    No, I don`t.
    888
    08:59 AM
    there is one tab in the material setting you havent shown and I suspect this is where your issue is.
    You need to go to the "graphics" tab. The "appearance" tab is for rendering, the graphics tab is where it will set your material shading/hatching in cut and projection for plans and elevations.
    Set this to white and I am pretty sure problem solved.
    2,689
    03:59 PM
    My guess, without seeing the model, the material isn't actually applied to the model. It might be applied to the family, but that's to say it made its way to the model. Can you upload an example? Or just the door family?
    April 24, 2017
    02:59 PM
    Attached Thumbnails Attached Thumbnails door_question 3.PNG   door_question 4.PNG   door-q-1.PNG   door-q-2.PNG   door-q-3.PNG
  1. Color Fill Legend - Transparent hatches have grey background not white..
    By josephpeel in forum Architecture and General Revit Questions
    Last Post: December 15th, 2016, 05:28 PM
  2. material transparency in elevation views
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: January 31st, 2016, 09:03 AM
  3. Logo experimentation - DWG can import as off-white, but not pure white
    By kescr in forum Architecture and General Revit Questions
    Last Post: December 24th, 2014, 03:15 PM
  4. Spot Elevation Issue
    Last Post: February 1st, 2013, 01:53 PM
  5. Material tag issue
    Last Post: November 28th, 2012, 04:10 PM
