Results 1 to 10 of 15
Thread: Insert views from File doesn't bring View Template over
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    219
    02:12 PM
    We use the 'insert views from file' command to bring our standard details into a project. However, the inserted views don't seem to bring the applied view template in with them. Is there any way for this to happen?
    Junior Member kiodour's Avatar
    February 17, 2013
    Jamaica
    6
    02:12 PM
    Quote Originally Posted by evan.dodds View Post
    "Manage" Tab > Transfer Project Standards> View Templates.
    Make sure to have both projects open.
    December 29, 2014
    Calgary, Canada
    219
    02:12 PM
    I did that and they are the same between both files. But, the view template gets set to <none> when the detail view is brought into a project.
    3,061
    12:12 PM
    I'm pretty certain that subtlety is missed by Insert from File. I don't recall it ever passing along a View Template assignment. It definitely does not bring the View Template along with it.
    December 29, 2014
    Calgary, Canada
    219
    02:12 PM
    Well pooey. Oh well.
    3,061
    12:12 PM
    It's really easy to assign the View Template to all of them once they've been added to the project though. Just select them all in the Project Browser and click the View Template button in the Properties Palette...choose the correct template...done.
    December 29, 2014
    Calgary, Canada
    219
    02:12 PM
    I know.... I just want to be lazy and have it done automatically. But I did just notice that schedules that are imported into a project do retain the view template assigned to them, so I guess that's where I got the idea that view templates are brought over for all views.
    July 29, 2014
    11
    08:12 PM
    Actually, I prefer not to have view templates brought over as I insert a view from another file.
    What if I have a view template with the same name in the file into which I want to insert that view? There'll be a clash & I can't keep both
    Wish Revit let us automatically rename 1 of them ...
    December 29, 2014
    Calgary, Canada
    219
    02:12 PM
    If the view templates originate from the same file then they shouldn't clash. At least, that doesn't happen for my schedule VTs (I have the VT in both my template and the file we keep our schedules in)
    Sent from my Nexus 5 using Tapatalk
    10,616
    02:12 PM
    FWIW, transferring over View Templates can get "interesting," depending on what the VT overrides. For instance, if you TPS in the View Templates, but dont bring the Filters, and Filters exist in that VT that dont exist in the new Project, it doesnt something weird. I dont remember if it fails to bring it over, or if it just drops the Filter, but im certain it doesnt automatically bring the Filter over, which is a PITA.
    Similarly, it cant bring over settings on Linked DWG or Linked RVT files, as they all have unique GUID's for the Links, and it *drops those* when it comes across.
    Just a few more things to think about with VT's and transferring.
  1. Overwriting Views Using Insert View From File
    By cordell in forum Architecture and General Revit Questions
    Last Post: February 17th, 2019, 12:41 AM
  2. Insert views from file?
    By tjkemp in forum Dynamo BIM
    Last Post: June 30th, 2016, 02:40 PM
    Last Post: October 31st, 2012, 08:16 AM
  4. RS BUG? Insert View from file...
    By snowyweston in forum Worksharing, Revit Server & C4R
    Last Post: June 14th, 2012, 08:33 AM
  5. Insert from File - Drafting Views
    By doabledave in forum Architecture and General Revit Questions
    Last Post: May 12th, 2011, 01:52 PM
