Thread: Pipe-in-pipe, containment pipe, double-wall pipe ?
    June 14, 2017
    06:25 PM
    Hey guys, first post here!
    I need help finding double wall pipe and was wondering if anyone can point me in the right direction. From what I understand, Revit does not have a double wall piping tool (is there an add-in that might be able to do this). I have read a lot of people are placing their pipe in the model and then just adding insulation to simulate the double wall pipe. I am hoping to actually be able to model it correctly as a double wall piping system.
    Thanks for the help!!
    Gerry
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    400
    04:25 PM
    If I absolutely HAD to model it as pipe in pipe due to pre-fab or BOM needs, then yes, model both pipes. If it is just for base design/coord, then I would go with the insulation route.
    This is where a savvy Dynamo user would write a tool that would effectively double up your pipe system in place with the new larger size for the containment...
    1,402
    12:25 AM
    I would suggest making a new Pipe Type (And Fittings) that has outside diameters consistent with the outer pipe for the inner pipe nominal diameters.
    That way you can model/change it easily without messing around with double pipes or insulation, and still use it in calculations.
    No one is ever going to see the inner pipe detail..
  1. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: July 8th, 2016, 02:56 PM
  2. pipe fittings and pipe valves size adjustment
    By Darius in forum Dynamo BIM
    Last Post: May 20th, 2016, 02:19 PM
  3. Pipe Settings dialog vs Pipe Systems
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: December 7th, 2015, 09:00 PM
  4. Double and triple stacked pipe break???
    By chefmark37 in forum MEP - General
    Last Post: June 30th, 2014, 11:24 AM
  5. Square/Rectangular Pipe: Is there a System Pipe this shape?
    By samz1 in forum Architecture and General Revit Questions
    Last Post: March 6th, 2014, 12:22 AM
