Results 1 to 10 of 10
Thread: Upgrade to 2018 - Dynamo doesn't open?
    Member RsqPrincess's Avatar
    October 3, 2011
    Wisconsin, USA
    60
    05:12 AM
    Our office is in the process of updating to Revit 2018. We were previously running 2016 (skipped 17) and had been using Dynamo 1.2.2.
    After installing Revit 2018, we tried opening Dynamo from the manage tab. Got this message:
Name:	Dynamo Error.jpg
    Looked at this page:
    Are you installing Revit-2018? | Dynamo BIM
    which tells me that 2018 ships with 1.2.2, and that if we had dynamo 1.0 - 1.2.1 installed, then we should be good to update.
    So I went to my add/remove programs and I had
    Dynamo 0.8.1 (edited due to typo)
    Dynamo Core 1.2.2
    Dynamo Revit 1.2.2
    So I removed 0.8.1 and installed 1.3.0 from the website, which replaced the 1.2.2.
    Restarted the computer, opened only revit 2018 with a new project. Same window.
    Did anyone else have this?
    Thanks!
    Member johnp's Avatar
    March 24, 2015
    180
    03:12 AM
    Dynamo 1.8.0?
    Go through and uninstall everything Dynamo related. Dynamo core, Dynamo Revit, Dynamo Studio and try a clean install.
    October 3, 2011
    Wisconsin, USA
    60
    05:12 AM
    haha, whoops, typo - "0.8.1"
    March 24, 2015
    180
    03:12 AM
    I would go ahead and remove all Dynamo installs still.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,570
    03:12 AM
    I just started R2018 for the first time, fired up Dynamo 1.2.2 without any issues. I have been using Dynamo 0.9.1 in R2015 and 1.2.1 in R2016 and those remain installed and working. I agree with johnp, uninstall it all and start over with an install of whatever the latest Dynamo is these days
    October 3, 2011
    Wisconsin, USA
    60
    05:12 AM
    update:
    I closed out of everything and uninstalled every Dynamo version on the "uninstall or change a program" list.
    Then went back to the website and downloaded 1.3.0, and restarted my computer.
    I opened up Revit 2018 with a new project, and chose not to use any template, in case it was something odd in my company template.
    Tried to open Dynamo - same window.
    ...But on the bright side, dynamo 1.3 opens great in Revit 2016...
    Our IT guy isn't sure what's going on here either, but he's looking into it also.
    3,291
    05:12 AM
    Have you seen this page on the Dynamo BIM forum?
    March 24, 2015
    180
    03:12 AM
    Did you uninstall Dynamo Core as well?
    October 3, 2011
    Wisconsin, USA
    60
    05:12 AM
    UPDATE: After quite a bit of trial and error it's been determined that Dynamo works if we remove the addin "VARevitLink2017.addin" which we had added in order to work with our Visual Analysis program.
    So if anyone does encounter this issue, it's worthwhile to look at which addins you have downloaded/added.
    https://knowledge.autodesk.com/suppo...-Products.html
    Thanks for the help!
    December 20, 2017
    04:12 AM
    Quote Originally Posted by RsqPrincess View Post
    Thank you for letting me know that. I've spent 12 hours to try to figure that out.
  1. Revit 2018 template upgrade failure
    By brane1012 in forum MEP - General
    Last Post: June 30th, 2017, 06:01 PM
  2. Revit 2018 Interoparability with 3dsMax 2018 not available?
    By willsud in forum Rendering and Gallery
    Last Post: May 6th, 2017, 05:16 AM
  3. Open Help Documents from dynamo.
    By swapr78 in forum Dynamo BIM
    Last Post: September 21st, 2016, 01:01 PM
  4. Revit 2015-Material Editor doesn't open
    By sand91123 in forum Architecture and General Revit Questions
    Last Post: July 15th, 2015, 08:12 AM
    Last Post: October 26th, 2014, 11:45 PM
