Thread: Shared Parameter Names Changing once loaded into project
    May 31, 2012
    Syracuse, NY
    180
    02:14 PM
    I'm in Revit 2017.2
    I have a shared parameter named Voltage_(company name)
    I have been re associating my connectors with my Voltage shared parameter and everything looks fine in the family editor
    When I load it into my project template and hit edit type, the parameter then shows as just "Voltage"
    So in the family editor it is showing properly as Voltage_Name
    This has not happened to me before
    I'm I missing something here? any help is appreciated
    Does revit now automatically rename all parameters that are under the same
    May 31, 2012
    Syracuse, NY
    180
    02:14 PM
    Oddly enough...when I get (Company name) to the front it carries over correctly....
    so Voltage_Eng converts to Voltage
    Eng_Voltage does not change....anyone else have this issue? I don't recall this being the case in 2014 when I last did a complete parameter rework like this
    January 18, 2014
    125
    01:14 PM
    Are they brand new parameters or did you edit the text of the SP file?
    May 31, 2012
    Syracuse, NY
    180
    02:14 PM
    I'm not sure how it was created I guess i should have made it clear that I did not literally create that parameter it has been with the company
    does editing in the text file cause weird issues like this? I've never tried it
    April 3, 2013
    25
    08:14 PM
    Do you not have a shared parameter file?
    2,680
    05:14 AM
    Quote Originally Posted by wgfletch View Post
    Yes it does, what cpercer said is most likely the issue. Creating new shared parameters is really the only way to update naming conventions although this will also lead to data loss. You might be able to use dynamo to export value then set new parameters.
    January 18, 2014
    125
    01:14 PM
    If you edit the text file you usually only change the name, like appending it with your company initials. The problem is the GUID stays the same so when you load it back into the project, the project uses the name stored with the GUID, not your new name.
    I was able to fix this by using RTV tools Shared Parameter Manager. I think the process involved duplicating the parameter list with new GUIDs. Then I ran the application on all of my families to switch out the old parameter with the new. This could be done manually by recreating your SP file from scratch and editing your family library, but who wants to do that?
  1. Shared Parameters Change Category when Loaded into Project
    By evan.dodds in forum Architecture and General Revit Questions
    Last Post: May 28th, 2015, 12:56 AM
  2. shared family and <family type.....> parameter, when loaded error
    By Bross in forum Structure - Family Creation
    Last Post: November 25th, 2013, 12:56 PM
  3. Issues changing parameter to shared
    By joshr in forum Architecture - Family Creation
    Last Post: September 28th, 2012, 10:39 AM
  4. Linestyles - Changing Names
    Last Post: March 8th, 2011, 02:09 AM
  5. Convert Project Parameter to Shared Parameter
    Last Post: January 5th, 2011, 08:35 AM
