Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: SysQue, Thoughts?
  1. #21
    March 22, 2019
    08:38 AM
    Chris, I'm new here but I'm curious about who you hired for the spooling piece and how this system is working for you now 3-4 years later. We use SysQue at my company, but I'm new to it and am skeptical of the cost benefit relationship.
    Thanks.
  2. #22
    July 13, 2015
    06:38 AM
    We're an engineering firm but sometimes work with local sub contractors that are overloaded and help assist them with detailing as well. We use Sysque primarily for plumbing only and have had great success in having one model for both engineering/ construction documents, coordination model/ VDC, shop drawings & spooling drawings. I've attached a few images of some of some of the plumbing spools from our single model. Also this was used on some very large scale projects.
ID:	36946Click image for larger version.
ID:	36947Click image for larger version.
  3. #23
    3,169
    06:38 AM
    I'd have given a 10, but the yellow Caution tag is missing
    Thanks for sharing!
  4. #24
    Forum Addict tzframpton's Avatar
    January 17, 2011
    2,104
    08:38 AM
    Fabrication tools are in Revit and work great for modeling. For pipe, not sure that an auto-spooling feature exists. I wonder if something is in the works, or if another add-in could take the FabParts items in Revit and make something from it?
    -TZ
  5. #25
    July 10, 2019
    02:38 PM
    Quote Originally Posted by Plumber View Post
    Thank you! I am pretty new to Revit, I just know some basics and currently I am the only one that does our CAD drawings for our company. So far I've only taken webinar for Revit training, obviously more formal training is required before we can full make the switch. We currently have a subscription to the Building Data database, that is where I get most of the fittings/valves/carriers that aren't in the Fabrication CADmap software OoTB. The other place I get stuff from is from the manufacturer's websites. I don't know enough to sit down and make all of the fitting families myself. Dafont Showbox Adam4adam Does SysQue work well with families other than their own, i.e. families downloaded from manufacturer's websites, other places like bim objects, building 3d content, smart bim, etc? I'm not sure what the Sysque spooling tool is like because I've never user it, I'm only familiar with spooling in Fabrication; what is the spooling tool like that your company uses? I have also heard the Vic Tool is fairly good, but it lacks a lot. Basically it's spooling tool is what it mostly has going for it, but even the videos I've seen on youtube it doesn't look overly impressive. I appreciate your help. It's a subject that is tough to get honest feedback on because usually no matter where you ask people either love it or hate it and there is no middle ground, everyone acts like your p***ing in their cheerios when you bring it up.
    If you have anyone thats good with Revit then the best thing is to just use out the box Revit & modify/create the family's you need. SysQue is good but very expensive but probably the only real option for you if you dont know Revit. SysQue's marketing will point out they have over a million parts which is great but in reality you will probable only ever use upto 100 fittings for pipework.
  6. #26
    May 21, 2018
    09:38 AM
    Victaulic has a cheap add on that works pretty good once you get used to it. Has some flange issues but still pretty good.
  7. #27
    Junior Member Plumber's Avatar
    May 9, 2017
    South Dakota, USA
    16
    08:38 AM
Name:	Spool - Blackout.png
    This is some underground sanitary sewer that was drawn using SysQue & spooled using Vic Tools
  1. sysque
    By Darius in forum MEP - General
    Last Post: July 26th, 2016, 05:53 PM
  2. sysque
    By Darius in forum Architecture and General Revit Questions
    Last Post: July 14th, 2016, 01:59 PM
  3. SysQue and C4R?
    By tzframpton in forum Worksharing, Revit Server & C4R
    Last Post: June 10th, 2016, 01:32 PM
  4. SysQue Anyone?
    By koolair in forum MEP - General
    Last Post: March 8th, 2015, 08:19 PM
