Thread: Lookup Table to drive data in Tags
    October 30, 2012
    24
    09:19 AM
    I am trying to create a tag that reads a simple number from 1 to 40 and returns another simple number for an FLS tag. I have created a lookup table in Excel, saved it as a CSV file, loaded it into a tag that I have created. The problem is, when I try to set up the formula telling Revit to use the lookup table, it tells me the lookup table is not a valid parameter. I'm attaching a screenshot of it. Is the problem that I am trying to drive information in the tag (can't be done) or the use of the lookup table (bad syntax or formatting)? Anyone familiar with using Lookup Tables, I would love some help.
    February 29, 2012
    66
    11:19 AM
    Hello,
    My understanding of Lookups, is that they must live in the (custom) family. It appears you are trying to connect the data to a room element, which as a system family would not be able to store the lookup info. For your example of occupancy, we would typically create that as a Key Schedule, which is a type of lookup. Perhaps that would be acceptable?
    Best Regards,
    Glynnis
    Precise BIM Data Management with 4 Revit Plugins | Ideate Software
    Revit Help topic:
    https://knowledge.autodesk.com/suppo...01B48-htm.html
    October 30, 2012
    24
    09:19 AM
    Thanks Glynnis. We have been using a Key Schedule to drive OLF values, but it's a manual process right now and we're trying to automate it. Might need to go back to the Key Schedule and try that again. Didn't realize that Lookups wouldn't work with a System Family.
  1. Model, Manufacturer, Lookup Table
    By RubberDinero in forum MEP - Family Creation
    Last Post: July 15th, 2016, 08:34 PM
    Last Post: October 19th, 2015, 05:15 AM
  3. Lookup table Yes/no not working
    By Arno in forum Architecture - Family Creation
    Last Post: September 28th, 2015, 06:21 PM
  4. Lookup Table: First Column?
    Last Post: September 27th, 2015, 11:09 PM
  5. Lookup Table issue
    By sabari2504 in forum MEP - General
    Last Post: January 15th, 2014, 08:19 AM
