Results 1 to 10 of 11
Thread: Grid extents per level. Z axis issue.
    2,753
    07:49 AM
    I have a project with radial grids that are unique on every level (don't ask, that's just the way it is.)
    ive generated all my grids from a rhino model using Dynamo however , by default these grids will also show up on the plan view above and below, if not all levels. So I can see the grids from level 6 on plan view 5 and 7. So Ive got all of my grids but my plans show grids from the level above and below. I don't want that. On level 6 I want to see only level 6 grids. On level 5 I want to see only level 5 grids. On level 7 I only want to see my level 7 grids....etc.
    There is a lot of grids! I dont want to have to create a perpendicular section for every single grid to manually adjust extents in the z direction.
    what should I do. Is there a Dynamo-ish way to read /write the z values of grids?
    890
    07:49 AM
    you could add them to a "phase" but this might cause more headaches than its Worth, otherwise add an identifier in mark or type mark, or create a new type for each level and then filter them out, either using comments, type mark (or some other text input identifier)
    Also if you just were to manually reduce them in their extents (vertically) they wont show in the views that they dont traverse....
    2,773
    02:49 PM
    You can't manage Scope Boxes with the API so that's out. I wonder if you could modify the grid extents directly with the API.
    4,435
    10:49 PM
    I'm going to get burned for this...
    Model lines.
    2,753
    07:49 AM
    Lol. I did think model lines. Or even reference planes. But all ive found with ref planes so far is per view application.
    Ideally i want to use grids but i am open to other ideas.
    Ill post my script tomorrow, its simple and works great but i want to acess those z values...
    1,405
    10:49 PM
    ?? They are accessible in dynamo, they can be copied, renamed and set if not created.
    If you can copy a starting scope box and move to each level that might work.
    How about this; Make a linked model with just grids in for every level (Or just one and place/rotate multiple instances if there is repetition). Set the extents of the grids in the link and place at each level... Doing it in a linked model might be better as a repeatable process. Copy grids, set a scope box with small height, save with level name, repeat. Adds an extra option for visibilty control too by turning links on and off in views.
    890
    07:49 AM
    Scope boxes I think is your answer, you might not be able to push that through dynamo but seems easiest...
    although I just found these....
    https://forum.dynamobim.com/t/contro...ope-box/8585/3
    https://dynamonodes.com/2016/02/14/s...-to-scope-box/
    2,773
    02:49 PM
    Not created then. Good point on copying. Assuming the level heights are consistent that should work well cause I don't think you can adjust them with the API (which is what I'd want).
    2,753
    07:49 AM
    OK here's my script. The layers are filtered by "GRID". I asked the designer to set grids per layer/level in the hope I can use this information in the future to set specific grids to Revit levels in the future, but this works for now.
    This method reads the grid geometry based on their elevation in rhino (everything is elevated from 0). I can create grids from curves (arcs or straight lines) too but this script uses start point and end point as the grids are all straight for this project.
    The north point rotation is there bc the rhino guy is "busy" and hasn't got his s*** together yet.
    The only custom package required here is Rhynamo.
    January 19, 2012
    346
    04:49 PM
    You can always use FILTERS. Just utilize a parameter, or create one assigned to Grids.
  1. Building Coder: Aligning a Slightly Off-Axis Grid
    Last Post: June 13th, 2017, 10:45 AM
  2. Extents of placed elevation below level of floor
    By Raff in forum Architecture and General Revit Questions
    Last Post: December 19th, 2014, 05:48 PM
  3. Irregular level extents in plan?
    By sharkmullet in forum Architecture and General Revit Questions
    Last Post: October 7th, 2013, 10:57 PM
  4. Dragging Grid and Level Ends
    Last Post: April 11th, 2012, 07:52 PM
  5. Level and Grid Question
    By dbakerstl in forum Architecture and General Revit Questions
    Last Post: June 9th, 2011, 02:47 AM
