Page 9 of 9 FirstFirst ... 56789
Results 81 to 89 of 89
Thread: RFO Benchmark v3.X
  1. #81
    November 13, 2019
    02:07 PM
    Has anyone ever found a fix for optimus not working in Revit on NVIDIA Quadro cards when on windows 10 1803 or 1903? Currently trying to get this to work on a Dell Precision 5520 that has an i5 7300HQ and an NVIDIA Quadro M1200 and I am getting numbers that of integrated graphics.
  2. #82
    November 20, 2019
    09:07 PM
    Hello Gordon,
    I'm using your RFO_Benchmark_v.3.2_2020 to benchmark Revit 2020. I encountered an error while trying to run "TerminateBenchmark_2020.ps1". I got this error: "Can't restore Revit.ini: failed to load XML file". It seems that it comes from the variable $revitVersion which is still '2019' so the file "RFOBenchmark_2019.xml" doesn't exist as the one which exists is "RFOBenchmark_2020.xml".
    Thanks for your work!
    Marc
  3. #83
    January 17, 2019
    Brussels, Belgium
    10
    09:07 PM
    Hello Gordon,
    I'm running some extensive testing on different machines both in Revit 2019.2.2 and 2020.2. (Some very beefy notebooks, some normal ones, a strong workstation and a virtual server).
    The RFO test for Revit 2019.2.2 runs just fine, but when I want to launch it for Revit 2020.2 It runs painstakingly slow, or not at all. Do you have any idea what the problem may be?
    Kind regards,
    Jonas
  4. #84
    October 18, 2019
    09:07 PM
    Hey Here's mine. On a zbook17 g4
    RVT 2020 - Full_Standard set - 2020.01.13 @ 10.13.21 on 124LTP0145.txt
    RFO Benchmark v3.2 (build 19.08.2019)
    RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2020.2
    __________________________________________________ _______________
    Update
    13.38 update previous version file
    Model creation benchmark
    5.97 opening and loading the custom template
    16.67 creating the floors levels and grids
    25.02 creating a group of walls and doors
    42.05 modifying the group by adding a curtain wall
    16.07 creating the exterior curtain wall
    12.88 creating the sections
    5.27 changing the curtain wall panel type
    18.94 creating area plans
    2.80 creating and applying view template
    145.67 TOTAL
    Export benchmark
    80.95 export all views as PNGs at 300 dpi
    72.89 export all views as DWFs
    120.71 export all views as DWGs
    84.79 print all views as vector *
    116.77 print all views as raster *
    Notes:
    * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
    119.59 render
    Graphics - Standard View
    6.74 activate View Styles view
    0.62 change view to Wireframe
    1.15 change view to Hidden
    1.47 change view to Shaded
    1.43 change view to Consistent Colors
    2.35 change view to Realistic
    1.15 refresh Wireframe Line view x10
    4.28 refresh Hidden Line view x10
    4.56 refresh Shaded view x10
    4.28 refresh Consistent Colors view x10
    4.77 refresh Realistic view x10
    0.60 activate View Cube view
    3.69 rotate view x1
    37.09 TOTAL
    Notes:
    Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: HP
    Model: HP ZBook 17 G4
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
    Max Clock Speed: 2.904Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 32GB @ 2400 2400Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: SAMSUNG MZVLW512HMJP-000H7
    Graphics Card: NVIDIA Quadro P3000
    Graphics RAM: 3.9990234375GB
    Driver version: 25.21.14.2553
    Screen Resolution: 1920x1080x32bit @ 60Hz
    DPI Scaling: 100%
    RAW DATA:
    13.723 13.363 13.043 update previous version file
    6.031 5.906 5.969 opening and loading the custom template
    17.137 16.625 16.254 creating the floors levels and grids
    24.633 25.684 24.742 creating a group of walls and doors
    41.062 44.168 40.910 modifying the group by adding a curtain wall
    16.086 16.453 15.668 creating the exterior curtain wall
    12.879 13.324 12.449 creating the sections
    5.246 5.406 5.168 changing the curtain wall panel type
    18.652 19.637 18.520 creating area plans
    2.773 2.852 2.766 creating and applying view template
    82.277 81.398 79.176 export all views as PNGs at 300 dpi
    73.633 73.344 71.691 export all views as DWFs
    122.328 123.973 115.844 export all views as DWGs
    86.988 86.418 80.961 print all views as vector
    118.676 117.723 113.914 print all views as raster
    119.980 114.836 123.957 render
    6.816 6.719 6.672 activate View Styles view
    0.648 0.602 0.617 change view to Wireframe
    1.207 1.066 1.180 change view to Hidden
    1.566 1.426 1.430 change view to Shaded
    1.453 1.398 1.430 change view to Consistent Colors
    2.305 2.281 2.453 change view to Realistic
    1.164 1.125 1.164 refresh Wireframe Line view x10
    4.344 4.227 4.262 refresh Hidden Line view x10
    4.707 4.488 4.492 refresh Shaded view x10
    4.359 4.258 4.230 refresh Consistent Colors view x10
    4.809 4.688 4.828 refresh Realistic view x10
    0.574 0.606 0.609 activate View Cube view
    3.723 3.660 3.680 rotate view x1
  5. #85
    February 7, 2012
    09:07 PM
    Questions for other people's Full_Standard test:
    Anyone noticing a difference with RAM configurations? I'm seeing almost identical results from 2666 vs 3200.
    Is the render test the most important, since we pan/rotate/zoom more than we export DWG? Model creation test is feeling pretty consistent for very different videocards (m4000 vs rtx 2080).
    My time of test results are all over the map. some machines are 3+ hours, others are under 20 minutes. Is there a time people normally see?
    Sam
  6. #86
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    261
    01:07 PM
    Regarding RAM, it should not be that big of a difference. When I tested 2400mhz vs either 3800 or 4000mhz (cant remember, was back when the 7th gen 7700k was new) the results only varied by 2-3 seconds, so from 2666mhz to 3200mhz I would not expect more than a 1 second difference. I use 3200mhz because it is the sweet spot in price to performance right now but in laptop builds I go 2666mhz because of the same reason as SODIMM prices are much different. Keep in mind your RAM timings matter too. A sloppy 3200mhz vs a tight timings 2666mhz can cause performance to be similar.
    the GPU portion of the RFO benchmark does not really vary much from what I have seen in these post. As long as you're not on the intel igpu it seems revit is happy. That said, I like the RTX 2060 as a good baseline Revit GPU but even the GTX 1660ti would do well, they just do not always have the video outputs I want.
    Quote Originally Posted by veryshinything View Post
    Sam
  7. #87
    February 11, 2017
    10:07 AM
    Is there a way to run the benchmark using the "viewer" flag? I have a license for Revit LT, but also have expired trials installed on my machine.
  8.    #88
    Phoenix, AZ
    2,774
    01:07 PM
    Getting a "process cannot access the file because it is being used by another process" from Notepad at the end of a run... any thoughts?
    Edit
    NM... I pulled the folder from Dropbox onto my desktop and it worked just fine. Guessing something to do with DB uploading at the same time the benchmark is trying to write to the file.
  9.    #89
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    260
    10:07 PM
    Benchmarking resolution is wrong. I'm not sure how this was mixed up, since this is the resolution I use at work on external monitor. And also, CPU is undervolted -165 mV if anybody cares.
    Code:
    RVT 2020 - Full_Standard set - 2020.03.28 @ 15.50.59 on LEGION-NR0MJ05.txt
        RevitForum.org
    Run on Revit 2020 FCS
    _________________________________________________________________
    Update
       11.01   update previous version file
        5.10   opening and loading the custom template
       14.21   creating the floors levels and grids
       19.97   creating a group of walls and doors
       33.78   modifying the group by adding a curtain wall
       13.07   creating the exterior curtain wall
       11.01   creating the sections
        4.26   changing the curtain wall panel type
       17.45   creating area plans
        2.63   creating and applying view template
      121.48   TOTAL
    Export benchmark
       69.28   export all views as PNGs at 300 dpi
       57.47   export all views as DWFs
       97.61   export all views as DWGs
       68.33   print all views as vector *
      103.35   print all views as raster *
    Notes:
    Render benchmark
       75.10   render
        5.57   activate View Styles view
        0.49   change view to Wireframe
        0.81   change view to Hidden
        0.99   change view to Shaded
        1.02   change view to Consistent Colors
        1.70   change view to Realistic
        0.86   refresh Wireframe Line view x10
        3.35   refresh Hidden Line view x10
        3.58   refresh Shaded view x10
        3.38   refresh Consistent Colors view x10
        3.78   refresh Realistic view x10
        0.46   activate View Cube view
        2.81   rotate view x1
       28.80   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: LENOVO
    Model: 81HE
    CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
    Max Clock Speed: 2.208Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 16GB @ 2667 2667Mhz
    Drive Model: NVMe WDC PC SN720 SDA
    Graphics Card: NVIDIA GeForce RTX 2070 with Max-Q Design
    Driver version: 26.21.14.4259
    Graphics Card: Intel(R) UHD Graphics 630
    Graphics RAM: 1GB
    Driver version: 25.20.100.6374
    Screen Resolution: 2560 2560x1440 1440x32bit @ 59 59Hz
    DPI Scaling: 100%
    RAW DATA:
       11.188   10.918   10.918   update previous version file
        5.055    5.117    5.117   opening and loading the custom template
       14.117   14.238   14.285   creating the floors levels and grids
       19.894   20.047   19.957   creating a group of walls and doors
       33.848   33.699   33.793   modifying the group by adding a curtain wall
       13.160   13.027   13.020   creating the exterior curtain wall
       11.098   10.910   11.016   creating the sections
        4.371    4.195    4.227   changing the curtain wall panel type
       17.766   17.133   17.457   creating area plans
        2.508    2.785    2.606   creating and applying view template
       69.324   69.160   69.359   export all views as PNGs at 300 dpi
       57.754   57.379   57.285   export all views as DWFs
       98.484   97.246   97.109   export all views as DWGs
       68.441   68.211   68.344   print all views as vector
      103.242  103.520  103.273   print all views as raster
       88.688   68.070   68.535   render
        5.574    5.574    5.562   activate View Styles view
        0.488    0.496    0.488   change view to Wireframe
        0.801    0.812    0.805   change view to Hidden
        0.984    0.980    1.016   change view to Shaded
        1.000    1.039    1.020   change view to Consistent Colors
        1.691    1.727    1.676   change view to Realistic
        0.863    0.875    0.852   refresh Wireframe Line view x10
        3.316    3.402    3.332   refresh Hidden Line view x10
        3.520    3.676    3.547   refresh Shaded view x10
        3.336    3.438    3.356   refresh Consistent Colors view x10
        3.715    3.898    3.730   refresh Realistic view x10
        0.445    0.477    0.453   activate View Cube view
        2.816    2.840    2.785   rotate view x1
  1. RFO Benchmark v3 2017 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: May 9th, 2018, 08:20 AM
  2. RFO Benchmark v3
    Last Post: August 28th, 2017, 01:18 AM
  3. RFO Benchmark 3.1 beta
    Last Post: August 18th, 2017, 08:51 PM
  4. RFO Benchmark v2
    Last Post: March 13th, 2017, 09:44 PM
