Page 2 of 11 FirstFirst 123456 ... LastLast
Results 11 to 20 of 109
Thread: RFO Benchmark v3.1 2018 results
  1. #11
    March 12, 2014
    03:20 PM
    Anyone here running this on Horizon View with nVidia Cards? The test VM has 2 vCPUs, 8GB RAM, XtremIO storage and nVidia K1 shared GPU
    Code:
    RVT 2018 - Full_Standard set - 2017.11.17 @ 09.26.17 on HMI05016.txt
        RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    Run on Revit FCS
    Update
       10.22   update previous version file
    Model creation benchmark
        3.40   opening and loading the custom template
       13.00   creating the floors levels and grids
       26.47   creating a group of walls and doors
       51.21   modifying the group by adding a curtain wall
       16.65   creating the exterior curtain wall
       11.50   creating the sections
        6.09   changing the curtain wall panel type
       15.06   creating area plans
        2.11   creating and applying view template
      145.49   TOTAL
    Export benchmark
       80.79   export all views as PNGs at 300 dpi
       64.49   export all views as DWFs
      129.97   export all views as DWGs
       72.18   print all views as vector *
      110.60   print all views as raster *
    Notes:
    Render benchmark
      298.14   render
    Graphics - Standard View
        6.22   activate View Styles view
        0.88   change view to Wireframe
        2.14   change view to Hidden
        2.51   change view to Shaded
        2.45   change view to Consistent Colors
        3.54   change view to Realistic
        1.76   refresh Wireframe Line view x10
        5.53   refresh Hidden Line view x10
        5.86   refresh Shaded view x10
        5.59   refresh Consistent Colors view x10
        6.05   refresh Realistic view x10
        0.71   activate View Cube view
        7.32   rotate view x1
       50.56   TOTAL
    Graphics - Sketchy View
        0.53   activate View Styles - Sketchy view
        4.91   change sketchy view to Wireframe
        2.51   change sketchy view to Hidden
        2.95   change sketchy view to Shaded
        3.04   change sketchy view to Consistent Colors
        2.97   change sketchy view to Realistic
        2.87   refresh sketchy Wireframe Line view x10
        6.70   refresh sketchy Hidden Line view x10
        7.06   refresh sketchy Shaded view x10
        6.80   refresh sketchy Consistent Colors view x10
        7.22   refresh sketchy Realistic view x10
        0.84   activate View Cube - Sketchy view
        7.09   rotate sketchy view x1
       55.49   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: VMware, Inc.
    Model: VMware Virtual Platform
    OS: Microsoft Windows 7 Professional -bit
    CPU:
    Max Clock Speed: 0Ghz
    Number of Processors:
    Number of Logical Processors:
    Total Physical Memory: 8GB @ Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: VMware Virtual disk SCSI Disk Device
    Graphics Card: NVIDIA GRID K160Q
    Graphics RAM: 2GB
    Driver version: 21.21.13.6917
    Graphics Card: VMware SVGA 3D
    Graphics RAM: 0.015625GB
    Driver version: 8.15.1.33
    Screen Resolution: xx32bit @ Hz
    RAW DATA:
       10.277   10.250   10.125   update previous version file
        3.438    3.375    3.387   opening and loading the custom template
       13.144   12.883   12.980   creating the floors levels and grids
       26.543   26.922   25.934   creating a group of walls and doors
       51.773   50.867   51.004   modifying the group by adding a curtain wall
       16.566   16.598   16.785   creating the exterior curtain wall
       11.457   11.504   11.531   creating the sections
        6.133    6.047    6.102   changing the curtain wall panel type
       15.035   15.144   15.000   creating area plans
        2.184    2.086    2.070   creating and applying view template
       80.551   80.949   80.871   export all views as PNGs at 300 dpi
       65.574   63.773   64.133   export all views as DWFs
      130.328  129.938  129.656   export all views as DWGs
       72.258   72.102   72.195   print all views as vector
      110.160  110.441  111.184   print all views as raster
      283.387  279.531  331.508   render
        6.211    6.148    6.301   activate View Styles view
        0.910    0.859    0.871   change view to Wireframe
        2.106    2.148    2.176   change view to Hidden
        2.586    2.453    2.488   change view to Shaded
        2.508    2.414    2.434   change view to Consistent Colors
        3.648    3.391    3.570   change view to Realistic
        1.742    1.758    1.777   refresh Wireframe Line view x10
        5.543    5.578    5.480   refresh Hidden Line view x10
        5.891    5.852    5.836   refresh Shaded view x10
        5.570    5.641    5.566   refresh Consistent Colors view x10
        6.082    6.004    6.059   refresh Realistic view x10
        0.715    0.699    0.715   activate View Cube view
        7.551    6.773    7.633   rotate view x1
        0.527    0.531    0.520   activate View Styles - Sketchy view
        4.875    4.836    5.027   change sketchy view to Wireframe
        2.598    2.430    2.492   change sketchy view to Hidden
        2.969    2.934    2.949   change sketchy view to Shaded
        3.059    3.078    2.992   change sketchy view to Consistent Colors
        2.941    3.070    2.898   change sketchy view to Realistic
        2.887    2.836    2.902   refresh sketchy Wireframe Line view x10
        6.762    6.648    6.695   refresh sketchy Hidden Line view x10
        7.109    7.012    7.047   refresh sketchy Shaded view x10
        6.785    6.828    6.781   refresh sketchy Consistent Colors view x10
        7.242    7.195    7.211   refresh sketchy Realistic view x10
        0.844    0.840    0.828   activate View Cube - Sketchy view
        7.156    7.039    7.086   rotate sketchy view x1
  2. #12
    11,098
    02:20 PM
    Yep. I've got numbers here running on VMWare horizon with a grid M60, 32 GB of RAM, and a few different processors. But the last benchmark I ran was the 2017 one.
    Aaron Maller
    Director
    Parallax Team, Inc.
  3. #13
    September 19, 2017
    4
    02:20 PM
    First time post and first time RFO Benchmark Run
    Well my first time posting to this forum... and very first run of RFO Benchmark tool.
    Interested in many more runs to compare multiple computers here.
    I've been looking for the Revit Benchmark tool... this one looks promising (it is my first).
    Questions:
    1. The Readme.txt file says the _RFO Benchmark - Full_Simplified does a single run without rendering or non HA graphics. Yet I saw my Revit close and restart 3 times. Also saw what I thought was rendering going on. Each of the first to launches of Revit did seem to only startup, then close revit... the last of the three runs loaded up a model and automatically put in multiple walls, furniture and copy the floors up. Is this what is expected behavior for the Full Simplified Run?
    2. Also, where is it that you incorporate the switches to control how many runs, and capturing the result to csv file?
    NOTE: I did have to edit .\Resources\Revit_2018.ini in line 17 to point to Revit 2018 folder instead of Revit 2017. But I was surprised that it looked to run the very first time.
    Code:
    RVT 2018 - Full_Simplified set - 2017.12.19 @ 11.56.42 on CORP-MIKEHU.txt
        RevitForum.org
    Run on Revit 2018.2
        5.27   opening and loading the custom template
       16.28   creating the floors levels and grids
       31.14   creating a group of walls and doors
       55.48   modifying the group by adding a curtain wall
       18.73   creating the exterior curtain wall
       13.59   creating the sections
        6.52   changing the curtain wall panel type
       18.00   creating area plans
        2.20   creating and applying view template
      167.21   TOTAL
    Graphics
        6.39   activate View Styles view
        2.42   change view to Wireframe
        0.21   change view to Hidden
        0.75   change view to Shaded
        0.82   change view to Consistent Colors
        0.91   change view to Realistic
        2.10   refresh Wireframe Line view x10
        7.83   refresh Hidden Line view x10
        8.30   refresh Shaded view x10
        8.01   refresh Consistent Colors view x10
        9.95   refresh Realistic view x10
        1.03   activate View Cube view
        5.70   rotate view x1
       54.42   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Hewlett-Packard
    Model: HP EliteBook 8770w
    OS: Microsoft Windows 7 Professional 64-bit
    CPU: Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz
    Max Clock Speed: 2.701Ghz
    Number of Processors: 4
    Total Physical Memory: 16GB @ Mhz
    Graphics Card: NVIDIA Quadro K3000M
    Graphics RAM: 2GB
    Driver version: 8.17.12.9703
    Graphics Card: DameWare Development Mirror Driver 64-bit
    Graphics RAM: 0GB
    Driver version: 1.1.0.0
  4. #14
    September 19, 2017
    4
    02:20 PM
    Wow! I let this run and left for home. Came in this AM and found 12 hours and 40 minutes bubble at the end of the task bar. to run RVT 2018 - Full_Expanded set.
    Is this expected - or is there something amiss?
    ALSO, I NEED TO GET THE DATA IN CSV... I've not been successful on adding the switch -csv to the target on the powershell launch shortcut.
    Code:
    RVT 2018 - Full_Expanded set - 2017.12.19 @ 14.47.39 on DSM-BRIANPA.txt
        RevitForum.org
    Run on Revit 2018.2
    Update
        7.41   update previous version file
        2.83   opening and loading the custom template
        0.04   saving the new project
       15.53   loading and arraying link
       19.67   setting links to halftone
        4.60   saving the project with links
       35.96   creating the floors levels and grids
       21.87   creating a group of walls and doors
       35.64   modifying the group by adding a curtain wall
       65.08   creating the exterior curtain wall
       25.26   creating the sections
       17.12   changing the curtain wall panel type
       20.95   creating area plans
        2.57   creating and applying view template
        1.08   saving the project with completed model
      268.20   TOTAL
    Export benchmark
     1072.83   export all views as PNGs at 300 dpi
      524.08   export all views as DWFs
     2296.39   export all views as DWGs
     2499.35   print all views as vector *
      459.69   print all views as raster *
    Notes:
    Render benchmark
       76.66   render
    Graphics - Activate first view
       34.03   activate View Styles view
    Graphics - Change view visual style from a common start
       21.90   common start: from Hidden Line to Wireframe
       23.85   common start: from Hidden Line to Shaded
       23.46   common start: from Hidden Line to Consistent Colors
       29.78   common start: from Hidden Line to Realistic
        7.94   common start: from Consistent Colors to Wireframe
       23.27   common start: from Consistent Colors to Hidden Line
       23.91   common start: from Consistent Colors to Shaded
       29.13   common start: from Consistent Colors to Realistic
      183.24   TOTAL
    Graphics - Change view visual style from a common end
       22.91   common end: from Wireframe to Hidden Line
       23.28   common end: from Shaded to Hidden Line
       23.23   common end: from Consistent Colors to Hidden Line
       23.24   common end: from Realistic to Hidden Line
       23.00   common end: from Wireframe to Consistent Colors
       23.36   common end: from Hidden Line to Consistent Colors
       23.42   common end: from Shaded to Consistent Colors
       23.27   common end: from Realistic to Consistent Colors
      185.71   TOTAL
    Graphics - Change view visual style in sequence
        7.84   in sequence: from Realistic to Wireframe
       22.83   in sequence: from Wireframe to Hidden Line
       23.81   in sequence: from Hidden Line to Shaded
       23.38   in sequence: from Shaded to Consistent Colors
       29.17   in sequence: from Consistent Colors to Realistic
       23.43   in sequence: from Realistic to Consistent Colors
       23.78   in sequence: from Consistent Colors to Shaded
       23.38   in sequence: from Shaded to Hidden Line
        7.96   in sequence: from Hidden Line to Wireframe
      185.58   TOTAL
    Graphics - Refresh views
       39.01   refresh Wireframe view x10
      107.34   refresh Hidden Line view x10
      110.32   refresh Shaded view x10
      108.54   refresh Consistent Colors view x10
      110.56   refresh Realistic view x10
      475.77   TOTAL
    Graphics - Rotate views
       13.81   activate View Cube view
       60.30   rotate view x1
        3.84   activate View Cube - Sketchy view
       98.52   rotate sketchy view x1
      176.47   TOTAL
    Notes:
        To meaningfully compare graphics cards, test all cards in the same machine.
    TEST CONDITIONS:
    Mfr: BOXX Technologies, Inc.
    Model: 3DBOXX W4150
    CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
    Max Clock Speed: 3.501Ghz
    Total Physical Memory: 32GB @ Mhz
    Graphics Card: NVIDIA Quadro K4000
    Graphics RAM: 3GB
    Driver version: 10.18.13.5442
    Graphics RAM: 0GB
    RAW DATA:
        8.106>    7.4180    7.3440    7.297<    7.4750   update previous version file
        2.8320    2.863>    2.8200    2.8360    2.816<   opening and loading the custom template
        0.031<    0.043>    0.0390    0.0390    0.0360   saving the new project
       15.5550   15.5270   15.5160   15.625>   15.340<   loading and arraying link
       19.953>   19.7150   19.5940   19.6950   19.505<   setting links to halftone
        4.5820    4.5940    4.875>    4.539<    4.6180   saving the project with links
       35.9300   36.0310   36.320>   35.641<   35.9230   creating the floors levels and grids
       22.090>   21.8710   21.9220   21.555<   21.8260   creating a group of walls and doors
       35.5200   35.7270   35.6880   35.891>   35.323<   modifying the group by adding a curtain wall
       64.7300   65.2420   65.2660   65.641>   64.652<   creating the exterior curtain wall
       25.000<   25.430>   25.3750   25.0860   25.3340   creating the sections
       17.0470   17.043<   17.2110   17.273>   17.0950   changing the curtain wall panel type
       21.547>   20.418<   21.1950   21.1170   20.5400   creating area plans
        2.5740    2.5590    2.617>    2.531<    2.5740   creating and applying view template
        1.0780    1.0780    1.125>    1.0780    1.076<   saving the project with completed model
     1078.379> 1072.2620 1073.9220 1072.3130 1070.668<   export all views as PNGs at 300 dpi
      528.539>  524.7810  523.3050  524.1410  521.243<   export all views as DWFs
     2296.0120 2294.125< 2294.3130 2299.125> 2298.8310   export all views as DWGs
     2497.8400 2500.4300 2499.7730 2504.992> 2488.122<   print all views as vector
      453.066<  455.0230  461.3050  462.7430  464.240>   print all views as raster
       88.543>   76.109<   76.4840   76.8460   76.6530   render
       33.9770   35.828>   33.906<   34.0640   34.0570   activate View Styles view
       21.8980   22.367>   21.742<   21.9740   21.8170   common start: from Hidden Line to Wireframe
       23.8630   24.539>   23.789<   23.8870   23.8140   common start: from Hidden Line to Shaded
       23.4800   24.578>   23.234<   23.4650   23.4300   common start: from Hidden Line to Consistent Colors
       29.9770   31.188>   29.430<   29.7270   29.6480   common start: from Hidden Line to Realistic
        7.9060    8.219>    7.867<    8.0160    7.9040   common start: from Consistent Colors to Wireframe
       23.2150   24.062>   23.031<   23.4810   23.1210   common start: from Consistent Colors to Hidden Line
       23.8440   24.984>   23.648<   24.1710   23.7130   common start: from Consistent Colors to Shaded
       29.430>   29.1640   28.828<   29.1360   29.0990   common start: from Consistent Colors to Realistic
       22.8980   23.078>   22.797<   23.0170   22.8080   common end: from Wireframe to Hidden Line
       23.344>   23.2810   23.062<   23.3110   23.2420   common end: from Shaded to Hidden Line
       23.2930   23.2110   23.125<   23.379>   23.1970   common end: from Consistent Colors to Hidden Line
       23.2810   23.2500   22.945<   23.419>   23.1780   common end: from Realistic to Hidden Line
       23.0550   23.0620   22.805<   23.140>   22.8940   common end: from Wireframe to Consistent Colors
       23.3940   23.3750   23.125<   23.448>   23.3000   common end: from Hidden Line to Consistent Colors
       23.5160   23.3980   23.188<   23.526>   23.3400   common end: from Shaded to Consistent Colors
       23.2620   23.3050   23.016<   23.522>   23.2470   common end: from Realistic to Consistent Colors
        7.8400    7.8830    7.773<    7.947>    7.7830   in sequence: from Realistic to Wireframe
       22.8280   22.8830   22.586<   22.997>   22.7930   in sequence: from Wireframe to Hidden Line
       23.7970   23.9060   23.570<   23.939>   23.7240   in sequence: from Hidden Line to Shaded
       23.3910   23.4060   23.156<   23.579>   23.3510   in sequence: from Shaded to Consistent Colors
       29.2730   29.289>   28.906<   29.2030   29.0470   in sequence: from Consistent Colors to Realistic
       23.4800   23.5160   23.227<   23.623>   23.2790   in sequence: from Realistic to Consistent Colors
       23.7810   23.8280   23.586<   23.984>   23.7360   in sequence: from Consistent Colors to Shaded
       24.543>   23.3520   23.094<   23.5330   23.2620   in sequence: from Shaded to Hidden Line
        8.117>    7.9220    7.852<    8.0670    7.8980   in sequence: from Hidden Line to Wireframe
       38.8050   39.2660   38.672<   39.732>   38.9720   refresh Wireframe view x10
      107.2230  108.0860  106.133<  108.851>  106.7260   refresh Hidden Line view x10
      110.1990  111.1720  109.5940  111.599>  109.062<   refresh Shaded view x10
      108.5510  109.2580  107.367<  109.559>  107.8030   refresh Consistent Colors view x10
      110.4690  111.1020  109.617<  113.828>  110.1080   refresh Realistic view x10
       13.8090   13.9380   13.945>   12.753<   13.6980   activate View Cube view
       59.4530   59.6410   59.000<   63.893>   61.8050   rotate view x1
        3.824<    3.8520    3.8360    3.862>    3.8350   activate View Cube - Sketchy view
       88.5700  117.6410   88.008<  118.024>   89.3520   rotate sketchy view x1
  5. #15
    June 2, 2013
    08:20 PM
    Model: HP Z VR Backpack G1 Workstation
    RVT 2018 - Full_Standard set - 2018.01.15 @ 10.29.41 on DESKTOP-8H4EQH8.txt
    RevitForum.org
    Run on Revit 2018.2
    __________________________________________________ _______________
    Update
    8.70 update previous version file
    3.39 opening and loading the custom template
    13.25 creating the floors levels and grids
    20.54 creating a group of walls and doors
    36.99 modifying the group by adding a curtain wall
    12.71 creating the exterior curtain wall
    12.24 creating the sections
    4.41 changing the curtain wall panel type
    16.81 creating area plans
    2.21 creating and applying view template
    122.55 TOTAL
    Export benchmark
    73.95 export all views as PNGs at 300 dpi
    55.14 export all views as DWFs
    112.20 export all views as DWGs
    68.92 print all views as vector *
    106.11 print all views as raster *
    Notes:
    Render benchmark
    88.60 render
    5.78 activate View Styles view
    0.62 change view to Wireframe
    0.98 change view to Hidden
    1.27 change view to Shaded
    1.27 change view to Consistent Colors
    2.05 change view to Realistic
    1.03 refresh Wireframe Line view x10
    3.93 refresh Hidden Line view x10
    4.21 refresh Shaded view x10
    4.01 refresh Consistent Colors view x10
    4.39 refresh Realistic view x10
    0.56 activate View Cube view
    3.36 rotate view x1
    33.46 TOTAL
    0.46 activate View Styles - Sketchy view
    2.36 change sketchy view to Wireframe
    1.34 change sketchy view to Hidden
    1.69 change sketchy view to Shaded
    1.73 change sketchy view to Consistent Colors
    1.53 change sketchy view to Realistic
    1.88 refresh sketchy Wireframe Line view x10
    4.78 refresh sketchy Hidden Line view x10
    4.96 refresh sketchy Shaded view x10
    4.79 refresh sketchy Consistent Colors view x10
    5.17 refresh sketchy Realistic view x10
    0.66 activate View Cube - Sketchy view
    12.50 rotate sketchy view x1
    43.85 TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
    CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
    Max Clock Speed: 2.904Ghz
    Total Physical Memory: 32GB @ 2667 2667Mhz
    Drive Model: SAMSUNG MZVLW512HMJP-000H1
    Graphics Card: NVIDIA Quadro P5200
    Graphics RAM: 3.9990234375GB
    Driver version: 22.21.13.8487
  6. #16
    June 2, 2013
    08:20 PM
    RevitForum.org
    Run on Revit 2018.2
    Update
    122.55 TOTAL
    Export benchmark
    Notes:
    Render benchmark
    88.60 render
    3.36 rotate view x1
    33.46 TOTAL
    43.85 TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
  7. #17
    1,628
    09:20 PM
    Bought a laptop last week en it runs the test pretty well, just a few things I don't really understand. It outpreforms all the tests compared to my workstation except the creating the floors levels and grids and activate View Styles view wich it does much worse then the workstation (4 time longer and 7 times longer). Any idea why those numbers are way off compared to the rest?
    Code:
    RVT 2018 - Full_Standard set - 2018.01.15 @ 15.37.25 on LAPTOP-DEURLOOB.txt
        RevitForum.org
    Run on Revit 2018.2
    Update
        8.36   update previous version file
        3.09   opening and loading the custom template
       62.20   creating the floors levels and grids
       20.51   creating a group of walls and doors
       37.29   modifying the group by adding a curtain wall
       12.89   creating the exterior curtain wall
       11.66   creating the sections
        4.40   changing the curtain wall panel type
       16.12   creating area plans
        1.96   creating and applying view template
      170.12   TOTAL
    Export benchmark
       75.72   export all views as PNGs at 300 dpi
       53.31   export all views as DWFs
      104.71   export all views as DWGs
       58.73   print all views as vector *
      103.93   print all views as raster *
    Notes:
    Render benchmark
      140.21   render
       53.02   activate View Styles view
        0.60   change view to Wireframe
        0.95   change view to Hidden
        1.19   change view to Shaded
        1.17   change view to Consistent Colors
        1.95   change view to Realistic
        1.02   refresh Wireframe Line view x10
        3.71   refresh Hidden Line view x10
        3.94   refresh Shaded view x10
        3.75   refresh Consistent Colors view x10
        4.13   refresh Realistic view x10
        0.51   activate View Cube view
        3.67   rotate view x1
       79.61   TOTAL
        0.50   activate View Styles - Sketchy view
        2.42   change sketchy view to Wireframe
        1.62   change sketchy view to Shaded
        1.61   change sketchy view to Consistent Colors
        1.49   change sketchy view to Realistic
        1.82   refresh sketchy Wireframe Line view x10
        4.51   refresh sketchy Hidden Line view x10
        4.76   refresh sketchy Shaded view x10
        4.58   refresh sketchy Consistent Colors view x10
        4.95   refresh sketchy Realistic view x10
        0.62   activate View Cube - Sketchy view
        4.20   rotate sketchy view x1
       34.42   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
    Model: HP Pavilion Power Laptop 15-cb0xx
    OS: Microsoft Windows 10 Home64-bit
    CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
    Max Clock Speed: 2.808Ghz
    Total Physical Memory: 16GB @ 2400 2400Mhz
    Drive Model: KXG50ZNV256G TOSHIBA
    Graphics Card: NVIDIA GeForce GTX 1050
    Graphics RAM: 2GB
    Driver version: 22.21.13.8569
    Graphics Card: Intel(R) HD Graphics 630
    Graphics RAM: 1GB
    Driver version: 22.20.16.4771
    Screen Resolution:  1920x 1080x32bit @  60Hz
    RAW DATA:
        9.363    7.879    7.844   update previous version file
        3.113    3.062    3.098   opening and loading the custom template
       62.863   60.691   63.031   creating the floors levels and grids
       20.367   20.512   20.644   creating a group of walls and doors
       37.367   37.219   37.285   modifying the group by adding a curtain wall
       12.777   12.887   13.016   creating the exterior curtain wall
       11.356   11.582   12.047   creating the sections
        4.387    4.371    4.434   changing the curtain wall panel type
       15.770   16.172   16.430   creating area plans
        1.965    1.938    1.969   creating and applying view template
       75.707   75.606   75.848   export all views as PNGs at 300 dpi
       53.074   53.379   53.465   export all views as DWFs
      104.938  104.230  104.961   export all views as DWGs
       57.832   59.758   58.602   print all views as vector
      102.789  105.004  103.996   print all views as raster
      148.523  136.953  135.160   render
       54.644   51.637   52.773   activate View Styles view
        0.590    0.602    0.617   change view to Wireframe
        0.969    0.926    0.945   change view to Hidden
        1.207    1.184    1.176   change view to Shaded
        1.188    1.148    1.188   change view to Consistent Colors
        1.969    1.938    1.934   change view to Realistic
        1.000    1.016    1.031   refresh Wireframe Line view x10
        3.707    3.699    3.738   refresh Hidden Line view x10
        3.949    3.930    3.941   refresh Shaded view x10
        3.742    3.754    3.742   refresh Consistent Colors view x10
        4.156    4.117    4.125   refresh Realistic view x10
        0.516    0.504    0.508   activate View Cube view
        3.707    3.730    3.586   rotate view x1
        0.492    0.504    0.504   activate View Styles - Sketchy view
        2.398    2.402    2.457   change sketchy view to Wireframe
        1.336    1.332    1.344   change sketchy view to Hidden
        1.617    1.625    1.633   change sketchy view to Shaded
        1.625    1.609    1.594   change sketchy view to Consistent Colors
        1.559    1.457    1.461   change sketchy view to Realistic
        1.820    1.816    1.828   refresh sketchy Wireframe Line view x10
        4.496    4.520    4.516   refresh sketchy Hidden Line view x10
        4.766    4.746    4.770   refresh sketchy Shaded view x10
        4.582    4.551    4.602   refresh sketchy Consistent Colors view x10
        4.957    4.965    4.934   refresh sketchy Realistic view x10
        0.613    0.617    0.617   activate View Cube - Sketchy view
        4.238    4.117    4.238   rotate sketchy view x1
  8. #18
    1,628
    09:20 PM
    below a comparisong between the 2 machines.
ID:	32600 Click image for larger version.
  9. #19
    Rotterdam, South Holland
    3,071
    08:20 PM
    Robin, that IS really odd. I have seen some funny business with the Activate Styles test, but not with the other. I would be curious to see the test run with GPU-Z running, to see if anything unusual happens during those tests. Trying a different version of the graphics driver might be worth a try too.
    I assume this is your personal machine, not an office machine where you could test another "identical" machine and see if the same thing happens?
    Gordon
  10. #20
    1,628
    09:20 PM
    OK, updates the graphics drivers and that helped.
    Went from 62,2 to 12,27 for creating the floors levels and grids
    Went from 53,02 to 5,31 for activate View Styles view
    and a few small improvements for other values as well
    So, overall pretty happy with my new laptop
    Code:
    RVT 2018 - Full_Standard set - 2018.01.17 @ 14.45.19 on LAPTOP-DEURLOOB.txt
        RevitForum.org
    Run on Revit 2018.2
    Update
        8.18   update previous version file
        3.08   opening and loading the custom template
       12.27   creating the floors levels and grids
       21.06   creating a group of walls and doors
       38.89   modifying the group by adding a curtain wall
       12.52   creating the exterior curtain wall
       11.74   creating the sections
        4.36   changing the curtain wall panel type
       16.26   creating area plans
        1.99   creating and applying view template
      122.17   TOTAL
    Export benchmark
       73.92   export all views as PNGs at 300 dpi
       53.96   export all views as DWFs
      104.66   export all views as DWGs
       58.60   print all views as vector *
      104.82   print all views as raster *
    Notes:
    Render benchmark
       92.62   render
        5.31   activate View Styles view
        0.58   change view to Wireframe
        0.94   change view to Hidden
        1.97   change view to Realistic
        3.69   refresh Hidden Line view x10
        3.93   refresh Shaded view x10
        4.11   refresh Realistic view x10
        3.76   rotate view x1
       31.93   TOTAL
        0.51   activate View Styles - Sketchy view
        2.32   change sketchy view to Wireframe
        1.31   change sketchy view to Hidden
        1.64   change sketchy view to Shaded
        1.62   change sketchy view to Consistent Colors
        1.45   change sketchy view to Realistic
        4.56   refresh sketchy Consistent Colors view x10
        0.61   activate View Cube - Sketchy view
        4.18   rotate sketchy view x1
       34.24   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
    Graphics RAM: 2GB
    Driver version: 23.21.13.8792
    Graphics RAM: 1GB
    Driver version: 22.20.16.4815
    RAW DATA:
        8.773    7.918    7.844   update previous version file
        3.043    3.062    3.148   opening and loading the custom template
       12.000   12.223   12.574   creating the floors levels and grids
       21.773   20.699   20.703   creating a group of walls and doors
       41.480   37.453   37.738   modifying the group by adding a curtain wall
       12.680   12.375   12.512   creating the exterior curtain wall
       11.629   11.801   11.785   creating the sections
        4.270    4.340    4.461   changing the curtain wall panel type
       16.113   16.418   16.234   creating area plans
        2.000    2.000    1.969   creating and applying view template
       74.262   73.328   74.180   export all views as PNGs at 300 dpi
       53.844   53.957   54.074   export all views as DWFs
      104.797  104.664  104.523   export all views as DWGs
       58.102   58.883   58.801   print all views as vector
      105.992  103.746  104.734   print all views as raster
       87.938  101.859   88.051   render
        5.262    5.297    5.371   activate View Styles view
        0.598    0.562    0.574   change view to Wireframe
        0.945    0.938    0.949   change view to Hidden
        1.203    1.188    1.176   change view to Shaded
        1.207    1.148    1.148   change view to Consistent Colors
        1.984    1.953    1.965   change view to Realistic
        1.016    1.016    1.016   refresh Wireframe Line view x10
        3.695    3.691    3.684   refresh Hidden Line view x10
        3.953    3.922    3.918   refresh Shaded view x10
        3.754    3.758    3.734   refresh Consistent Colors view x10
        4.121    4.074    4.141   refresh Realistic view x10
        0.520    0.512    0.512   activate View Cube view
        3.883    3.621    3.781   rotate view x1
        0.508    0.504    0.504   activate View Styles - Sketchy view
        2.328    2.316    2.328   change sketchy view to Wireframe
        1.328    1.309    1.289   change sketchy view to Hidden
        1.652    1.613    1.641   change sketchy view to Shaded
        1.621    1.629    1.617   change sketchy view to Consistent Colors
        1.449    1.426    1.469   change sketchy view to Realistic
        1.820    1.809    1.820   refresh sketchy Wireframe Line view x10
        4.516    4.504    4.512   refresh sketchy Hidden Line view x10
        4.758    4.750    4.758   refresh sketchy Shaded view x10
        4.566    4.543    4.559   refresh sketchy Consistent Colors view x10
        4.957    4.957    4.934   refresh sketchy Realistic view x10
        0.621    0.606    0.613   activate View Cube - Sketchy view
        4.094    4.309    4.152   rotate sketchy view x1
  1. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  2. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  3. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
