Page 3 of 11 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 106
Thread: RFO Benchmark v3.1 2018 results
  1. #21
    2,719
    09:17 AM
    Hmmm - never considered the graphics card would make that much of a difference in these tests. Interesting.
  2. #22
    1,489
    05:17 PM
    nope, me neither, but it seems it really did
  3. #23
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    252
    08:17 AM
    Wow that was interesting. Might as well share this since we are on the topic. One thing I do that is likely unnecessary is make sure the Nvidia geforce experience does not get installed during the driver installation. Most of the features in there are really gamer related and the only potential benefit is that it will remind you when a new update is available. It becomes annoying as drivers come out often especially when new major games are released.
    To avoid installing it just click advanced install during the beginning of the driver install and uncheck the geforce experience box and your set.
    Last edited by remiscs; January 18th, 2018 at 08:05 AM. Reason: typo- meant to write unnecessary rather than necessary
  4. #24
    October 2, 2015
    11:17 AM
    Question for this group..Has anyone noticed increase benchmark results with the CPU is overclocked. I am noticing that even though the CPU is overclocked. RFO results is not showing that in the results. So is it not recommended to run RFO benchmark on a overclocked CPU ?
  5. #25
    May 18, 2015
    Las Vegas, NV
    252
    08:17 AM
    Quote Originally Posted by drscrewup View Post
    It is fine to run on an overclocked CPU. It should scale as well but I technically have not run the 2018 version yet. Stability of your OC is what I would question as I commented in the CPU thread.
  6. #26
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    08:17 AM
    For those that keep wondering how the test runs with SLI... FYI, I got the SLI setup to run Star Citizen. Played Battlefield 4 last night and it was awesome running full ultra.
    Code:
    RVT 2018 - Full_Standard set - 2018.02.04 @ 11.12.06 on DESKTOP-0QNTL8A.txt
        RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    Run on Revit 2018.2
    Update
        8.84   update previous version file
    Model creation benchmark
        3.62   opening and loading the custom template
       21.51   creating the floors levels and grids
       25.13   creating a group of walls and doors
       38.30   modifying the group by adding a curtain wall
       16.58   creating the exterior curtain wall
       19.38   creating the sections
        4.95   changing the curtain wall panel type
       25.34   creating area plans
        2.88   creating and applying view template
      157.69   TOTAL
    Export benchmark
       82.08   export all views as PNGs at 300 dpi
       53.70   export all views as DWFs
      116.03   export all views as DWGs
       71.51   print all views as vector *
      125.05   print all views as raster *
    Notes:
    Render benchmark
       45.13   render
    Graphics - Standard View
        6.23   activate View Styles view
        0.58   change view to Wireframe
        0.86   change view to Hidden
        1.15   change view to Shaded
        1.12   change view to Consistent Colors
        1.91   change view to Realistic
        0.97   refresh Wireframe Line view x10
        4.00   refresh Hidden Line view x10
        4.12   refresh Shaded view x10
        4.04   refresh Consistent Colors view x10
        4.30   refresh Realistic view x10
        0.57   activate View Cube view
        5.27   rotate view x1
       35.12   TOTAL
    Graphics - Sketchy View
        0.83   activate View Styles - Sketchy view
        2.88   change sketchy view to Wireframe
        1.38   change sketchy view to Hidden
        1.71   change sketchy view to Shaded
        1.69   change sketchy view to Consistent Colors
        1.44   change sketchy view to Realistic
        1.84   refresh sketchy Wireframe Line view x10
        4.83   refresh sketchy Hidden Line view x10
        4.99   refresh sketchy Shaded view x10
        4.91   refresh sketchy Consistent Colors view x10
        5.15   refresh sketchy Realistic view x10
        0.66   activate View Cube - Sketchy view
       23.75   rotate sketchy view x1
       56.06   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Gigabyte Technology Co., Ltd.
    Model: X299 AORUS Gaming 9
    CPU: Intel(R) Core(TM) i7-7820X CPU @ 3.60GHz
    Max Clock Speed: 3.6Ghz
    Number of Processors: 8
    Number of Logical Processors: 16
    Total Physical Memory: 64GB @ 2133 2133 2133 2133Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: INTEL SSDPED1D480GA
    Graphics Card: NVIDIA GeForce GTX 1080
    Graphics RAM: 3.9990234375GB
    Driver version: 23.21.13.9077
    Screen Resolution:  3840x 2160x32bit @  59Hz
    RAW DATA:
       10.426    7.965    8.129   update previous version file
        3.606    3.496    3.758   opening and loading the custom template
       21.816   20.695   22.008   creating the floors levels and grids
       25.074   25.606   24.699   creating a group of walls and doors
       38.367   37.828   38.719   modifying the group by adding a curtain wall
       16.773   16.215   16.766   creating the exterior curtain wall
       20.859   18.332   18.945   creating the sections
        5.121    4.566    5.172   changing the curtain wall panel type
       25.711   25.449   24.871   creating area plans
        2.859    2.875    2.898   creating and applying view template
       79.230   84.707   82.316   export all views as PNGs at 300 dpi
       53.750   53.644   53.703   export all views as DWFs
      114.543  119.773  113.770   export all views as DWGs
       70.606   73.039   70.891   print all views as vector
      120.703  129.254  125.199   print all views as raster
       45.062   44.695   45.641   render
        6.109    6.383    6.211   activate View Styles view
        0.582    0.570    0.578   change view to Wireframe
        0.848    0.867    0.856   change view to Hidden
        1.148    1.152    1.152   change view to Shaded
        1.125    1.106    1.133   change view to Consistent Colors
        1.941    1.902    1.894   change view to Realistic
        0.977    0.961    0.984   refresh Wireframe Line view x10
        4.023    3.996    3.984   refresh Hidden Line view x10
        4.098    4.121    4.144   refresh Shaded view x10
        4.074    4.016    4.027   refresh Consistent Colors view x10
        4.297    4.262    4.332   refresh Realistic view x10
        0.562    0.555    0.594   activate View Cube view
        5.160    5.293    5.356   rotate view x1
        0.770    0.863    0.863   activate View Styles - Sketchy view
        2.582    2.996    3.059   change sketchy view to Wireframe
        1.332    1.281    1.527   change sketchy view to Hidden
        1.656    1.711    1.754   change sketchy view to Shaded
        1.613    1.707    1.738   change sketchy view to Consistent Colors
        1.441    1.473    1.402   change sketchy view to Realistic
        1.824    1.816    1.871   refresh sketchy Wireframe Line view x10
        4.785    4.820    4.883   refresh sketchy Hidden Line view x10
        4.926    4.965    5.066   refresh sketchy Shaded view x10
        4.992    4.859    4.879   refresh sketchy Consistent Colors view x10
        5.160    5.168    5.133   refresh sketchy Realistic view x10
        0.688    0.664    0.637   activate View Cube - Sketchy view
       21.879   24.805   24.559   rotate sketchy view x1
  7. #27
    10,727
    10:17 AM
    So, uh.... These are the results, on the new 15 inch BIMBOX Stryker Laptop. Running in full 4k resolution. Its, um, freaking fast.
    RVT 2018 - Full_Standard set - 2018.02.10 @ 20.11.54 on PRLXBBS01.txt
    RevitForum.org
    Run on Revit 2018.2
    __________________________________________________ _______________
    Update
    7.32 update previous version file
    3.08 opening and loading the custom template
    11.25 creating the floors levels and grids
    18.41 creating a group of walls and doors
    32.49 modifying the group by adding a curtain wall
    11.40 creating the exterior curtain wall
    10.30 creating the sections
    3.89 changing the curtain wall panel type
    14.10 creating area plans
    1.91 creating and applying view template
    106.83 TOTAL
    Export benchmark
    60.00 export all views as PNGs at 300 dpi
    45.63 export all views as DWFs
    115.93 export all views as DWGs
    54.68 print all views as vector *
    88.21 print all views as raster *
    Notes:
    Render benchmark
    60.51 render
    3.84 activate View Styles view
    0.48 change view to Wireframe
    0.83 change view to Hidden
    1.05 change view to Shaded
    1.01 change view to Consistent Colors
    1.68 change view to Realistic
    0.84 refresh Wireframe Line view x10
    3.63 refresh Hidden Line view x10
    3.79 refresh Shaded view x10
    3.67 refresh Consistent Colors view x10
    3.97 refresh Realistic view x10
    0.48 activate View Cube view
    3.87 rotate view x1
    29.14 TOTAL
    0.55 activate View Styles - Sketchy view
    1.94 change sketchy view to Wireframe
    1.13 change sketchy view to Hidden
    1.41 change sketchy view to Shaded
    1.42 change sketchy view to Consistent Colors
    1.26 change sketchy view to Realistic
    1.52 refresh sketchy Wireframe Line view x10
    4.28 refresh sketchy Hidden Line view x10
    4.45 refresh sketchy Shaded view x10
    4.28 refresh sketchy Consistent Colors view x10
    4.65 refresh sketchy Realistic view x10
    0.55 activate View Cube - Sketchy view
    16.63 rotate sketchy view x1
    44.07 TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Notebook
    Model: P7xxTM1
    CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
    Max Clock Speed: 3.696Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 64GB @ 2400 2400 2400 2400Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics Card: NVIDIA GeForce GTX 1070
    Driver version: 23.21.13.8792
    Screen Resolution: 3840x2160x32bit @ 59Hz
    RAW DATA:
    7.336 7.344 7.281 update previous version file
    3.055 3.086 3.094 opening and loading the custom template
    11.141 11.375 11.242 creating the floors levels and grids
    18.250 18.492 18.492 creating a group of walls and doors
    32.430 32.625 32.422 modifying the group by adding a curtain wall
    11.188 11.461 11.555 creating the exterior curtain wall
    10.148 10.312 10.430 creating the sections
    3.812 3.898 3.953 changing the curtain wall panel type
    14.016 14.102 14.172 creating area plans
    1.867 1.961 1.891 creating and applying view template
    59.320 60.758 59.930 export all views as PNGs at 300 dpi
    45.531 45.656 45.711 export all views as DWFs
    115.719 116.406 115.656 export all views as DWGs
    54.477 55.008 54.555 print all views as vector
    87.836 88.883 87.898 print all views as raster
    52.953 60.547 68.039 render
    3.867 3.766 3.883 activate View Styles view
    0.492 0.469 0.492 change view to Wireframe
    0.836 0.805 0.859 change view to Hidden
    1.031 1.055 1.070 change view to Shaded
    1.008 1.016 1.000 change view to Consistent Colors
    1.703 1.672 1.680 change view to Realistic
    0.875 0.820 0.828 refresh Wireframe Line view x10
    3.586 3.656 3.641 refresh Hidden Line view x10
    3.758 3.805 3.797 refresh Shaded view x10
    3.664 3.672 3.680 refresh Consistent Colors view x10
    3.984 3.992 3.930 refresh Realistic view x10
    0.477 0.477 0.477 activate View Cube view
    3.852 3.867 3.898 rotate view x1
    0.586 0.523 0.555 activate View Styles - Sketchy view
    1.984 1.930 1.906 change sketchy view to Wireframe
    1.125 1.141 1.117 change sketchy view to Hidden
    1.406 1.391 1.430 change sketchy view to Shaded
    1.430 1.430 1.398 change sketchy view to Consistent Colors
    1.266 1.250 1.266 change sketchy view to Realistic
    1.516 1.516 1.516 refresh sketchy Wireframe Line view x10
    4.336 4.266 4.250 refresh sketchy Hidden Line view x10
    4.523 4.398 4.414 refresh sketchy Shaded view x10
    4.320 4.250 4.266 refresh sketchy Consistent Colors view x10
    4.719 4.617 4.617 refresh sketchy Realistic view x10
    0.562 0.539 0.539 activate View Cube - Sketchy view
    16.672 16.500 16.719 rotate sketchy view x1
  8. #28
    2,719
    09:17 AM
    Think it would be even faster if you weren't pushing 4k? Minimal I'm sure.
  9. #29
    10,727
    10:17 AM
    I saw a decent different on the Dell between 1920 and 2560, so I have to imagine so.
    Aaron Maller
    Director
    Parallax Team, Inc.
  10. #30
    Member TRWhitehead's Avatar
    February 16, 2012
    Portland, OR
    329
    08:17 AM
    Um, this is on a nearly 2 year old desktop. Something seems off.
    RVT 2018 - Full_Standard set - 2018.02.20 @ 12.31.59 on WS-16-40.txt
    RevitForum.org
    Run on Revit 2018.2
    Update
    7.21 update previous version file
    2.74 opening and loading the custom template
    10.11 creating the floors levels and grids
    17.67 creating a group of walls and doors
    32.39 modifying the group by adding a curtain wall
    10.65 creating the exterior curtain wall
    8.81 creating the sections
    3.74 changing the curtain wall panel type
    11.83 creating area plans
    1.65 creating and applying view template
    99.59 TOTAL
    Export benchmark
    57.92 export all views as PNGs at 300 dpi
    46.67 export all views as DWFs
    90.51 export all views as DWGs
    52.14 print all views as vector *
    84.63 print all views as raster *
    Notes:
    Render benchmark
    97.90 render
    4.91 activate View Styles view
    0.52 change view to Wireframe
    0.95 change view to Hidden
    1.16 change view to Shaded
    1.14 change view to Consistent Colors
    1.81 change view to Realistic
    0.89 refresh Wireframe Line view x10
    3.66 refresh Hidden Line view x10
    3.89 refresh Shaded view x10
    3.71 refresh Consistent Colors view x10
    4.05 refresh Realistic view x10
    0.49 activate View Cube view
    5.60 rotate view x1
    32.78 TOTAL
    0.74 activate View Styles - Sketchy view
    2.31 change sketchy view to Wireframe
    1.36 change sketchy view to Hidden
    1.58 change sketchy view to Shaded
    1.57 change sketchy view to Consistent Colors
    1.38 change sketchy view to Realistic
    1.64 refresh sketchy Wireframe Line view x10
    4.42 refresh sketchy Hidden Line view x10
    4.62 refresh sketchy Shaded view x10
    4.55 refresh sketchy Consistent Colors view x10
    4.92 refresh sketchy Realistic view x10
    0.60 activate View Cube - Sketchy view
    17.87 rotate sketchy view x1
    47.56 TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: HP
    Model: HP Z240 Tower Workstation
    CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
    Max Clock Speed: 4.001Ghz
    Number of Processors: 4
    Total Physical Memory: 32GB @ 2133 2133 2133 2133Mhz
    Drive Model: NVMe SAMSUNG MZVPV256 SCSI Disk Device
    Graphics Card: NVIDIA Quadro M2000
    Driver version: 22.21.13.8205
    RAW DATA:
    7.438 7.098 7.086 update previous version file
    2.715 2.715 2.797 opening and loading the custom template
    10.102 9.965 10.262 creating the floors levels and grids
    17.672 17.562 17.770 creating a group of walls and doors
    32.246 32.508 32.406 modifying the group by adding a curtain wall
    10.637 10.621 10.688 creating the exterior curtain wall
    8.730 8.738 8.965 creating the sections
    3.699 3.766 3.758 changing the curtain wall panel type
    11.606 11.816 12.070 creating area plans
    1.629 1.644 1.668 creating and applying view template
    57.949 57.727 58.098 export all views as PNGs at 300 dpi
    46.688 46.809 46.520 export all views as DWFs
    90.606 90.445 90.473 export all views as DWGs
    51.676 51.504 53.234 print all views as vector
    83.426 83.562 86.906 print all views as raster
    125.254 89.102 79.332 render
    4.734 4.809 5.184 activate View Styles view
    0.512 0.531 0.516 change view to Wireframe
    0.922 0.957 0.965 change view to Hidden
    1.188 1.129 1.152 change view to Shaded
    1.141 1.125 1.160 change view to Consistent Colors
    1.781 1.809 1.832 change view to Realistic
    0.875 0.887 0.894 refresh Wireframe Line view x10
    3.629 3.637 3.719 refresh Hidden Line view x10
    3.859 3.891 3.926 refresh Shaded view x10
    3.703 3.691 3.742 refresh Consistent Colors view x10
    4.023 4.055 4.074 refresh Realistic view x10
    0.469 0.531 0.480 activate View Cube view
    5.965 5.434 5.410 rotate view x1
    0.695 0.492 1.047 activate View Styles - Sketchy view
    2.164 2.527 2.238 change sketchy view to Wireframe
    1.445 1.285 1.344 change sketchy view to Hidden
    1.531 1.578 1.621 change sketchy view to Shaded
    1.586 1.559 1.570 change sketchy view to Consistent Colors
    1.352 1.379 1.410 change sketchy view to Realistic
    1.606 1.676 1.625 refresh sketchy Wireframe Line view x10
    4.383 4.387 4.488 refresh sketchy Hidden Line view x10
    4.602 4.594 4.668 refresh sketchy Shaded view x10
    4.465 4.461 4.727 refresh sketchy Consistent Colors view x10
    4.766 4.883 5.109 refresh sketchy Realistic view x10
    0.555 0.555 0.691 activate View Cube - Sketchy view
    17.902 17.785 17.914 rotate sketchy view x1
  1. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 09:20 AM
  2. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 12:39 PM
  3. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 01:00 AM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 03:08 PM
