Thread: rvt family on level 1 showing on level 2
    August 1, 2017
    06:01 PM
    I have a FCU that is placed on level 1 ref. level and is showing on level 2 floor plans. My view range isn't set to go below associated level, I dont have an Underlay, I also checked that floors are ON so its not just viewing thru the floor, but for some reason its visible on Level 2.
    How or why is this happening?
    Ive searched this forum but all fixes result in view range which I believe this to be something was different. Anyone seen this or know how to fix?.. besides hiding element..
    August 1, 2017
    06:01 PM
    Ok so this is going to seem silly, I just figured out how to fix it...
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,522
    04:01 PM
    Fan Coil Unit? Have you checked that there is nothing in the family that would make it taller? Sometimes there is a rouge reference plane beyond the bounds of the elements and it makes the family much larger. A plan region over the affected area can be a quick way to verify it isn't view range (set it really high or really low). Make sure the element hasn't been offset from the floor it's placed on too.
    August 1, 2017
    06:01 PM
    Thats exactly what i found out a few minutes after i posted this.... I wsa checking the unit in elevation and noticed reference line moving in level 2...
    4,435
    11:01 PM
    Howard, good to hear you're sorted, but in future please don't multi-post.
  1. level 1 showing in level 2
    By rockstm in forum Architecture and General Revit Questions
    Last Post: December 24th, 2015, 09:03 AM
  2. Reference for family not showing on 1 level only
    Last Post: March 22nd, 2013, 01:08 PM
  3. Windows from upper level showing up in lower level
    Last Post: January 10th, 2013, 02:18 PM
  4. Railings showing up on the level below
    Last Post: May 1st, 2012, 01:29 PM
