Hi fellow Reviteers:
I've created a simple dynamo script for batch upgrading your families.....
you will need the Rythym and clockwork packages.
Note that this DOES NOT create a copy of your files, so you should have them copied into a new aptly named directory
Be very careful and use at own risk.
Comments welcome
Nice job man! The only feedback I have is, in newer versions of Rhythm the open nodes have changed, so they will need replaced, unfortunately.
Here are the replacement nodes names/locations.
Yeah, both have stayed present for a bit. I am retiring the python versions on next release.
The rhythm package now has a node specifically for this.
https://dynamonodes.com/2017/11/06/b...gradefamilies/
Niceone... I should have waited!
Hi Alex
This is exactly the tool I am looking for. I'm a complete Dynamo newbie but a pretty competent Revit user.
I've downloaded the Dynamo script but there's errors around the "Application.OpenDocumentFile". Makes me summise that the Rhythm thingy fixes this issue. My problem is that I have no idea how to use the Rhythm input to write that script!
Tips and tricks welcome.
thanks
B
