Thread: Railing "Edit Profile" similar to wall "Edit Profile"?
    Member lost again again's Avatar
    March 10, 2011
    Northern California
    370
    07:04 AM
    I have an exterior deck with railing attached to the outside. I want to run a set of stairs along side and its railing, attached to the outside of the stringers, is to align vertically with the deck railing above. Where these two railings intersect, the stair railing should stop at the deck railing, resulting in a triangular portion of star railing. I was hoping to find a tool similar to "edit profile" for walls, that would let me modify the stair railing's shape in elevation (see attached image).
    Is there a tool or some trick to making a portion of railing triangular? Or maybe this configuration of stairs adjacent to a deck is not practical and so nobody has done this? It seems possible, and I'm sure I've seen an actual similar condition where a railing fills in the triangular space between a stair and a floor above (where in Revit the stair could conflict with the floor above without being obvious, I guess).
    Attached Thumbnails Attached Thumbnails Screen Shot 2017-10-25 at 8.49.29 AM.png
    3,130
    08:04 AM
    Haven't tried this, but I'd guess you could Edit the Railing's Path (the magenta Sketch line) and split it at the bend.
    Then you can select the top half and change it's properties to "flat".
    You'll have to figure out yourself where to break it to get the flat part at the right height. I don't believe Revit can help with that.
    March 10, 2011
    Northern California
    370
    07:04 AM
    Thanks for the idea - I hadn't thought about trying that. Unfortunately, this moves the problem to the bottom, because the railing is still rectangular in the triangular space.
    Whangarei, New Zealand
    184
    03:04 AM
    Quote Originally Posted by lost again again View Post
    Nothing to add to this to help you (yet) but I currently have a project where I need exactly the same thing.
    I'm eagerly awaiting an answer to this, but will keep trying to work it out when I get back to my project.
    Sent from my SM-G950F using Tapatalk
    March 10, 2011
    Northern California
    370
    07:04 AM
    Quote Originally Posted by Chris Needham View Post
    Thank you for the confirmation. I've also confirmed with my architect that the condition does indeed exist in the real world, and so the question is now doubly not moot.
    For now, I'm editing the stair railing sketch to delete the portion that conflicts with the horizontal railing above and will see how far into the project I can hide this missing element. I hope this is resolved before someone actually falls through the hole between stair and deck above at the project site.
  1. why split topography doesn't have "edit surface" option
    By zohreh in forum Architecture and General Revit Questions
    Last Post: June 29th, 2016, 03:14 PM
  2. "Edit Family" command from project Glitch
    By mendler in forum Architecture and General Revit Questions
    Last Post: April 25th, 2016, 11:35 PM
  3. Gate as "door" in curtainwall "railing"
    By CADiva in forum Architecture and General Revit Questions
    Last Post: November 25th, 2014, 05:05 PM
  4. change instance parameter w/ "Edit" for multiple views/sheets
    Last Post: October 22nd, 2014, 09:56 AM
  5. Analytical adjust for "Edit Profile" wall.
    By bjarkeoervad in forum Structure - General Questions
    Last Post: March 13th, 2014, 10:28 AM
