Thread: Creating Rounded Cube Family- Help Please!!
    November 4, 2017
    06:14 PM
    I can't figure out how to get my sweep to correctly turn my cube extrusion into a rounded or filleted cube. I haven't used a sweep to create a new form in several years and can't figure it out, but need to desperately. Please help me figure out the best way to do this
    (looking for something like this https://t00.deviantart.net/OHmW43U85...94-d40vdi8.jpg)
    Thanks
    6,389
    06:14 PM
    Create the cube as an extrusion, then use a void sweep to round off the top & bottom.
    and as a side note - deviant art is a great site but I'd wager that some companies have it filtered. I'd recommend either uploading directly to the forum or using a different image host.
    May 20, 2011
    Chicago, IL
    811
    05:14 PM
    ...or, round off by adding vs. subtracting.
ID:	31987   Click image for larger version.
ID:	31988   Click image for larger version.
    6,389
    06:14 PM
    Quote Originally Posted by PijPiwo View Post
    in hindsight I probably like that method more.
    New Member millyferry's Avatar
    November 13, 2017
    Mississauga, ON
    05:14 PM
    Nice thoughts on cube extrusion.
    Last Post: September 25th, 2013, 03:45 AM
  2. Schedule values need to be rounded up. Can I do this?
    By DMapes in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2012, 06:33 PM
  3. Lines: no rounded dash.....?
    By jbenoit44 in forum Architecture and General Revit Questions
    Last Post: December 8th, 2011, 01:34 PM
  4. Building Coder: Basic Parametric Cube Family Tutorial
    By Blog Fetcher in forum Blog Feeds
    Last Post: July 1st, 2011, 09:21 AM
