Thread: Materials and Phasing
    June 21, 2012
    Tours, France
    1,066
    06:25 AM
    Hi guys,
    I'm working on a project that needs to have Phasing and design options, that's ok I'm already create my phasing scheme and my design options and all works nice.
    A little issue I'm facing right now is that some building elements will be re-painted in lieu of demolished, so I need to keep those elements but I'm trying to know if one can give a Phase just to a specific material?, is that possible?, I'm not sure if Revit allows me to create a material that is present in one phase and is replaced (Demolished) in the next one?, am I clearly enough?, all your comments and ideas are very welcome, regards
    1,483
    06:25 AM
    This is something I wanted right from the first project I ever did in Revit and as far as I know it is not possible. The paint tool does not do phasing. Only way I can think of is to demolish the thing you want to paint and build a new one with the right color. Definatelly not how it should work !
    June 21, 2012
    Tours, France
    1,066
    06:25 AM
    Hi Robin and many thank's for you response, Yes that was my fist thought about this subject but I wanted to hear other thoughts/Ideas about the way to achieve this, actually i'm modeling the object twice and that works fine, very sad that you cannot dissociate materials and assigning it a phase, thanks again regards
    Member Geert's Avatar
    February 8, 2011
    155
    06:25 AM
    Perhaps model the paint as a very thin wall? This method will not compromise sceduling.
    June 21, 2012
    Tours, France
    1,066
    06:25 AM
    Hi Geert, no, since it's a curtain wall that should be just re-painted, I guess that model it twice is a better idea, but thank you so much for your response and suggestion, kind regards
    April 22, 2012
    Santiago, Chile
    66
    02:25 AM
    I posted that to Revit Ideas, but it got archived due to lack of community support ().
    https://forums.autodesk.com/t5/revit.../idi-p/6480380
  1. Renaming Materials - Only Working on Some Materials
    By cellophane in forum Dynamo BIM
    Last Post: April 13th, 2019, 10:40 AM
  2. Phasing (Again)
    By ThatBIMGuy in forum Architecture and General Revit Questions
    Last Post: July 20th, 2016, 03:22 AM
  3. Phasing and Phasing Filters
    By jess_labbe in forum Structure - General Questions
    Last Post: April 7th, 2015, 05:18 PM
  4. Phasing Takoff
    By Dyd666 in forum Architecture and General Revit Questions
    Last Post: January 16th, 2013, 06:59 PM
  5. Phasing and Rooms
    By ncebula in forum Architecture and General Revit Questions
    Last Post: October 12th, 2011, 03:02 PM
