Thread: If statement formular - Help
    New Member Mathias Milling's Avatar
    November 29, 2017
    Odense, Denmark
    09:37 PM
    Question If statement formular - Help
    Hi everybody
    I'm having some trouble with an if statement formular. I'm new to the if formulars and maybe I can't do, what I wanna do.
    My goal is to return the largest value of two area values.
    In this case my parameter value Area1, and not "Area1".
    My formular is like this: And i have attatched a image as well.
    if(Area1 > Area2, "Area1", "Area2")
    Thanks in advance.
    Mathias
Name:	if statement.PNG
    November 29, 2017
    Odense, Denmark
    09:37 PM
    Hi again.
    I found a solution on my own.
    I change the parameter type, so all of them are the same, in my case area.
    Then my formular looks like this:
    if(Area1 > Area2, Area1, Area2)
    Then it returns the largest of the two values to my parameter container.
    3,194
    02:37 PM
    Glad you figured it out.
    But it was the quote marks that were the problem, not the parameter type.
    Although it might have been both.
    March 21, 2013
    275
    01:37 PM
    Quote Originally Posted by Mathias Milling View Post
    Hi again.
    FYI, It might not matter, but that formula will return Area2 in the case they are both equal. (Area1 is not greater than Area2) You can rearrange their order to determine which one will be returned if they are equal.
  1. If Else Statement
    By Mimi Azimar in forum Dynamo BIM
    Last Post: May 26th, 2017, 08:57 AM
  2. Help with IF statement?
    By ryntau in forum Dynamo BIM
    Last Post: February 22nd, 2017, 09:49 AM
  3. IF Statement Help...
    By dynodan1uk in forum Architecture - Family Creation
    Last Post: April 21st, 2015, 10:58 AM
  4. If statement help
    By mkisno4 in forum Architecture - Family Creation
    Last Post: April 20th, 2015, 10:35 PM
  5. IF statement help
    Last Post: August 16th, 2013, 04:59 PM
