Thread: ELEVATION(level from origin) IN DOOR/LINTEL TAG FAMILY
    June 9, 2011
    70
    01:06 AM
    Hi everyone,
    I attempting to create a door that incorporates a lintel (shared family).
    The problem comes when I tag this family. I would like to show the elevation (from the base point) in the tag instead of using the ôspot elevationö tool.
    I have no idea how to achieve this.
    Thank you in advance.
    June 21, 2012
    Tours, France
    1,097
    01:06 AM
    Quote Originally Posted by Thasso00 View Post
    Hi everyone,
    The problem comes when I tag this family. I would like to show the elevation (from the base point) in the tag instead of using the “spot elevation” tool.
    Hi; I'm assuming that you are talking about Nested Family when you say shared family, So is quite simple actually, you must edit your Door Tag and add a Height label which you'll find when you hit on the add label tool, see image, my Revit is in french but I'm sure that in English is pretty much the same thing, hope this helps, regards
Name:	door height.PNG
ID:	32507   Click image for larger version.
Name:	door height_2.PNG
    June 9, 2011
    70
    01:06 AM
    Thank you for you quick reply.
    However, what I need is the level from the project base point.
    In think you can say "arase inferieur du linteau par rapport Ó l'origine du projet" in French.
    June 21, 2012
    Tours, France
    1,097
    01:06 AM
    Hi Thass00, I got it, so basically is the same explanation but you need to look for the parameter called Height under lintel, Headroom height , Height under header (or something like that) and add it to your TAG, sorry I don't remember the name of that parameter in English, hope this helps
Name:	door height_3.PNG
ID:	32513   Click image for larger version.
    2,712
    10:06 AM
    Not sure if doors (or anything else?) are aware to that degree ootb? Dynamo can quite easily compare your values and write them to custom parameter/s if needed
  1. Door with Beam (lintel)
    By marino melo in forum Structure - Family Creation
    Last Post: May 13th, 2016, 01:21 PM
  2. 2016 Custom Door Opening Family w/ Nested Lintel Geometry
    By Kyle Roseman in forum Architecture and General Revit Questions
    Last Post: January 28th, 2016, 11:43 PM
  3. Locking the origin of a line based family in the host family
    By Karzan in forum Architecture - Family Creation
    Last Post: April 1st, 2015, 10:30 PM
    Last Post: March 4th, 2013, 11:15 PM
  5. Can't change family origin point, family loads into project as hidden lines
    Last Post: February 1st, 2013, 04:51 PM
