Thread: Import RAM Element to Revit 2017
    January 16, 2018
    06:08 AM
    Hello Family, Need some help/ guidance on the steps to import RAM elements structure into Revit 2017. Steel structure.
    Thanks
    Moderator LeanneZ's Avatar
    Charlotte, NC
    795
    07:08 AM
    Hello Ekaf...
    I'm going to move this thread to the Revit Structure Forum, under the subforum "Structure - Interoperability" You may search there to see if there is any more help.
    Simple instructions: I do know that you need to use the Bentley ISM add-in that will help facilitate this process. In RAM Elements, you'll create an ISM repository. Then, in Revit, you'll import from that ISM repository.
    January 16, 2018
    06:08 AM
    Thank LeanneZ
    Last Post: April 8th, 2017, 07:17 AM
  2. import de mobiler Archicad dans Revit (2017)
    By samaconda in forum Forum Franais
    Last Post: March 20th, 2017, 02:30 PM
    Last Post: March 18th, 2017, 07:15 AM
    Last Post: March 7th, 2017, 03:45 AM
  5. Import/Export Element Information
    By bmm in forum Third party Add-Ins, API and R&D
    Last Post: February 20th, 2014, 12:02 PM
