Thread: Reference Plane Visibility
    3,192
    06:22 PM
    I've been updating old families trying to get them to be more consistent lately.
    The thought occurred to me that it might be nice to easily identify what Reference Planes are Named, Strong, Weak, or Not a Reference.
    So I created sub-categories under Reference Planes and (sadly) manually changed the Planes to their proper sub-category.
    All well and good so far, but as you can see in my screenshot, they pick up the color, but not the Line Weight assigned.
    Scale makes not difference, nor does Thin Lines.
    (And, yes, I know the sub-cats get uselessly imported to the Project. Not thrilled about that, either.)
    Apparently, this feature is not complete. Or is this intentional?
    August 19, 2011
    New Hampshire
    511
    07:22 PM
    I get around that by adjusting the lengths of the reference planes. Longer ones have more importance than shorter ones.
    6,329
    07:22 PM
    In the project environment the RP will respect the line weight (and can be filtered if you use a selection set), but it doesn't look like it works in the family editor. That could be as-intended or a bug, no way to tell Personally - I would say it is broken and should work that way in the family as well.
    and it's too late now, but you can modify sub-categories in the family through Dynamo. You would need to tweak the graph to look at RP properties but you should be able to get them.
    edit: realized i put the wrong graph & image up, I'll fix it after my meeting
    edit2: new image & graph attached
    6,329
    07:22 PM
    OK - getting the Is Reference value as something other than a number might be tricky. I have a post on the Dynamo Forum if you want to follow along: https://forum.dynamobim.com/t/refere...eference/18200
  1. Reference Plane Visibility
    By HLBbarrett in forum MEP - General
    Last Post: May 12th, 2019, 04:53 PM
  2. Reference plane
    By Rubyak in forum Tutorials, Tips & Tricks
    Last Post: August 8th, 2017, 06:03 PM
  3. Reference Plane
    Last Post: June 21st, 2016, 02:57 PM
  4. Wishlist - Right-click on named reference plane, set as work plane.
    By ryntau in forum Architecture - Family Creation
    Last Post: September 22nd, 2015, 05:30 PM
  5. Any way to know what's on a reference plane?
    By psubrian in forum Architecture and General Revit Questions
    Last Post: October 23rd, 2014, 02:57 PM
