Thread: Odd cutting behavior
    3,194
    03:06 PM
    I can't figure out why one of these sinks is cutting as expected and the other doesn't cut all the way through.
    The right-hand one was created by selecting the one on the left and "Create Similar" so they are the same thing.
    But the left one doesn't cut properly.
    In fact, if you use the Cut Geometry tool. you can't even select it.
    What's up with that? They should be identical.
    3,127
    01:06 PM
    What does it report for host? Place it again from scratch, different result? Pick New?
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    438
    08:06 AM
    Pick New did not work here.
    But I moved it off the benchtop into space (Warning: Elements do not intersect. > Don't Cut Geometry.), then moved it back onto the bench and it immediately cut the surface.
    Could not see what caused it.
    3,194
    03:06 PM
    Very weird.
    Original host reports the Countertop as expected.
    When I try to Pick New Host, I get:
    "Element cannot be mirrored or rotated in a manner that changes its angle relative to the ground."
    Even if I copy the Countertop & move it over. So I know it's parallel.
    However, I did a Cut and Paste Aligned to Same Place and that one works fine.
    The other thing that's weird with the original one's cutting it if you spin around so yo're under it, the sink bowl disappears.
  1. Materials Odd Behavior
    Last Post: July 6th, 2017, 09:50 AM
  2. Odd Behavior For Rotating Families
    By taffind in forum MEP - Family Creation
    Last Post: May 17th, 2017, 04:34 PM
  3. View Filter Behavior
    By SuperDave in forum Architecture and General Revit Questions
    Last Post: April 7th, 2014, 11:07 PM
  4. InstallGUID behavior
    Last Post: May 14th, 2013, 02:06 AM
  5. Extrusion Behavior Question
    By jhenry58 in forum Architecture - Family Creation
    Last Post: March 2nd, 2012, 07:52 PM
