Thread: how to calculate the surface area?
    September 10, 2011
    10:13 AM
    How to calculate the lateral of column surface area which is visual?
    TKS!
    Nantes, France
    1,381
    12:13 PM
    you can use paint by face, using a material named Visible_col_area, then make a material schedule.
    otherwise, you will have to deal with calculated values with shared parameters, but it will be hard to have only visible area.
    good luck.
    3,231
    06:13 AM
    Yes, as Julien said, paint the surfaces, then create a material take-off schedule.
    Also, for take-off schedules, please refer to:
    http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/1394-Document1394/1476-Schedule1476/1483-Material1483
Name:	area of surfaces.jpg
  1. Room and Area Calculations - Calculate Ratio
    By mdradvies in forum Tutorials, Tips & Tricks
    Last Post: June 8th, 2017, 12:28 PM
  2. Replies: 15
    Last Post: July 31st, 2014, 07:24 PM
  3. Help with area selection
    By sharons in forum Architecture and General Revit Questions
    Last Post: June 20th, 2011, 10:57 AM
  4. Concrete Beam surface Area Schedule - Problem
    By G Jowett in forum Structure - General Questions
    Last Post: February 15th, 2011, 09:54 PM
