Results 1 to 10 of 10
Thread: Get Count % in Schedule
    Arsham
    Guest
    i have 129 unit and 5 unit types, i created a schedule and sorted them by Unit Types,
    now what i want is to create another column which shows the percentage of each unit type based on the total,
    any ideas? thanks
    3,291
    11:02 AM
    This thread may help
    https://www.revitforum.org/tutorials...-schedule.html
    Not exactly what you're trying to do, but I think you should be able to adapt the concept.
    11,017
    11:02 AM
    You actually dont need a formula to do it at all. Just make a Calculated Value, and set it to "Percantage" instead of Formula, and make it a "percentage" of "Grand Total."
    Arsham
    Guest
    it won't let you to select Count as % of Grand Total.
    Arsham
    Guest
    it doesn't let me select Count for %, in order to do that, i have to combine it with another parameter,
    and then the issue is that i can't use a combined parameter in formula.
    Arsham
    Guest
    ok , what i need to do is to create a new number parameter, select all the rooms and set that parameter as 1 for all of them,
    then it'll let me select the new parameter in a calculated value as a percentage.
    thanks guys.
    6,389
    12:02 PM
    You need a dummy parameter to take the place of Count:
    https://www.revitforum.org/blog-feed...-schedule.html
    11,017
    11:02 AM
    Sorry, i forgot about that. To work around it i have a Shared Parameter called item_Count, and i used the Family Processor to go through my entire damn library, and set that value locked to 1 in every family i have, LOL. Makes using Count in a formula a bit easier.
    July 31, 2017
    04:02 PM
    If you don't want to add share parameters and all that just add a calculated value as Count: If(Area > 1,1,1)
    Then do the percentage from this one
    You don't need to update parameters or do anything else
    May 23, 2011
    Netherlands
    589
    05:02 PM
    A fixed Calculated Value does not really need a formula. Just write a '1'.
  1. Sort Schedule by Count
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: June 30th, 2015, 06:13 PM
  2. Suffix behind count in schedule
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: November 21st, 2012, 06:31 PM
  3. Schedule Count Question
    By mikey1073 in forum Architecture and General Revit Questions
    Last Post: September 19th, 2012, 04:19 PM
    Last Post: April 18th, 2012, 07:15 AM
  5. Schedule: Count only what's shown in schedule...
    Last Post: July 17th, 2011, 03:57 PM
