Thread: How to change imported in-place wall material
    February 22, 2018
    03:17 PM
    Unhappy How to change imported in-place wall material
    Created an in-place wall, then imported a SAT file (exported from Rhino), and... that's it, cannot change the material.
    Here are some things I have tried:
    - Select the imported object in the family editor and change the material in the properties panel, but that parameter doesn't appear.
    - Explode the imported object in the family editor, but that button doesn't appear.
    - Import the SAT file as a Generic Model, but Revit will allow me to import it as a Wall only, with all its limitations.
    - Change the structural material in the type parameter, but nothing changes.
    - Cry, but the problem persists.
    I'm using Revit 2018
    Any ideas, please?
    July 10, 2015
    Boise, Idaho
    776
    01:17 PM
    Yes. Don't use 3rd party software to create Revit content. It doesn't cooperate well
    June 21, 2012
    Tours, France
    1,102
    09:17 PM
    Quote Originally Posted by supereq View Post
    LOL you make my day with that , and for your problem, As already evoked by @DavidLarson it may be a very good idea to not do that, but if you have no choice you can do as follows:
    Go to >Manage > Object Styles > Imported Objects, once then you need to find your imported file, once then you can change the material and for consequence its appearance. hope this can help you stop crying
    890
    06:17 AM
    If you are just worried about a render appearance you could "cheat" by just using the "paint surface" tool which will apply the texture/finish of your chosen material from your material library to the face of the object but it will not apply it to the material globally so if you have a lot of surfaces to "fix" the appearance of this will take you a while using this method and for the purpose of lists will not solve anything.
  1. Revit does not allow me to change material of imported object
    By soonk in forum Architecture - Family Creation
    Last Post: February 15th, 2018, 07:55 AM
  2. Wall material can not change
    By Somaya in forum Architecture and General Revit Questions
    Last Post: November 7th, 2015, 08:10 PM
  3. imported SAT model in family - wall align place
    By tomassok in forum Structure - Family Creation
    Last Post: January 14th, 2015, 01:51 PM
  4. How to change the material of imported dwg object in a project or family editor?
    Last Post: November 18th, 2011, 09:07 PM
