Thread: Family Parameter in Schedule
    October 23, 2016
    10:09 PM
    I'm having trouble with importing a parameter into a Furniture Schedule.
    The specific family can be found here.
    In a family like the one above how can a parameter like Height be added to a schedule with the correct value for each instance.
    I have added instances of the bookshelf Family and changed the height value for each one.
    Initially the Height parameter did not show up when creating a furniture schedule.
    Then I linked the parameters with a Shared parameter.
    The issue is that with a shared parameter I get the same value displayed for each instance of the family inside the schedule.
    I hope this makes sense. Any help would be much appreciated.
    Thanks
    October 14, 2011
    Boston, MA
    227
    04:09 PM
    strange, this worked fine for me.
    Double check that Height is a shared parameter and double check it is the same parameter in the schedule.
    Also check that the height parameter is set to Instance
    3,194
    03:09 PM
    Its very possible to have two different parameters with the same name in Revit.
    The simplest way to find that out is to create a new Schedule of the Category - in your case, Furniture.
    If you see two "Height" parameters in the "Available fields" column, they will not report the same information
    Last Post: January 10th, 2018, 07:15 AM
    Last Post: February 24th, 2016, 03:15 AM
    Last Post: August 5th, 2014, 03:45 PM
  4. select by parameter? curtain wall panels' materials by parameter, by type or family?
    Last Post: January 24th, 2013, 03:20 PM
  5. In-Place Family Parameter in Multi-Category Schedule?
    Last Post: August 25th, 2011, 10:22 PM
